T TangMan50 Founding Member Dec 26, 2000 1,328 0 36 Apr 9, 2010 #1 Apr 9, 2010 #1 Can someone point me to the valve springs that are needed when upgrading to a B303 using the stock heads?
liljoe07 5 Year Member Feb 18, 2009 1,622 363 124 Cartersville,Ga Apr 9, 2010 #2 Apr 9, 2010 #2 Choices are limited. FRPP A50 springs or the Trick flow kit will drop right in.
5 57fairlane New Member Apr 2, 2005 560 0 0 Oakwood, GA Apr 9, 2010 #3 Apr 9, 2010 #3 check the spring rate on your stock springs. If they still have life in them you should be fine . . . I've seen stock springs run b cams, even a f.
T TangMan50 Founding Member Dec 26, 2000 1,328 0 36 Apr 9, 2010 #4 Apr 9, 2010 #4 Thanks! Are you talking about this kit here from TrickFlow? http://www.latemodelrestoration.com...low-50l-302-Mustang-Valve-Springs-Upgrade-Kit
liljoe07 5 Year Member Feb 18, 2009 1,622 363 124 Cartersville,Ga Apr 10, 2010 #5 Apr 10, 2010 #5 Yep, that's the kit.
