A common test is to run on the highway, remove foot from accelerator which produces a strong vacuum in the intake. After a few seconds, punch the accelerator and see if you get a puff of blue smoke. If so, blame it on the valve seals and replace them... They can let vacuum pull oil past the seal which lets it run down the intake valve and into the combustion chamber when it will produce smoke...
no that dosent happen, it pretty much stopped after i changed the pcv, even if they are a little worn, i just bought all new pi intake, exhaust, head, valve stem,valve cover,and timing cover gaskets for my head swap
