I know some of you guys on here are very knowledgeble on engines, so here is my question. I am getting some lifter noise on my Cobra clone after she is warmed up. I installed a Lunati cam 284 dur/ 488 lift with new springs and lifters. I used new pushrods and comp cams magnum roller rockers with the positive stop lock nuts. After she is warmed up it sounds like a solid cam !! I have pulled the valve covers-rotated the engine and all seems fine. The pushrods are 6.875" in length. I measured the old pushrods and they are the same. Could it be from the rockers ?? If so I know ford 302s also use 6.905" and 6.883" length pushrods. Should I go to a longer push rod? Lastly I am dissapointed because it almost sounds stock, I thought this cam would have a little thumpity thump.
