valves hanging open
stevesLX
373
cincinnati
O.K. I took my car back by the machine shop today and had 3 differn't guys listen to it run. I have had lifter noise since I put it back together. These are stock heads which had a 3 angle valve job done to them. 89 302. All three said its valves hanging open and not allowing the lifter to pump all the way up. They are telling me I need to shim my pushrods. Right now I have .045 preload. I have some shims for pedestal trockers from crane cams and they are .030 and .060. If I put a .030 shim in my preload will be down to like .010 -.015. I know Crane Cams says preload should be .020-.060. They say to do that and the valves will shut and the lifters will pump up and all my ticking will go away. Its quiet at idle but if you rev it up or drive it it sounds like a steam train. Does what they are telling me sound right or not?
