Vert folks with Kenny Brown Extreme Subframe System
1992 2.3LX
885
Ky
For those of you with Verts and this setup, i am curious as to how much of an improvement this kit gives?
I am tired of my car turning to a bowl of jello when the top is down and i get on it. i want to add (quite a bit) of stability. Which is extremely lacking right now with the top down.
Will the Kenny Brown Extreme Subframe System (jacking rails, subframe connectors, and matrix braces) give me more stability than shocks, struts and springs??
Both will be done eventually just need to do it in steps. and i want to do the one that i will get more handling benfits from first.
No KB. Go MM, MM is better. KB doesnt extemd from torque boxes to front firewall. Max. Motorsports subs do.
P.S> i used to have the KB system. So my opinion is mine, not based on word of mouth.
O since you have a vert i would do that first since they are only like $250 installed. If possible, go with a quality set of shocks&struts(tokico/bilstien) at the same time that way you can decide if you really need to lower your car to achieve the handling/ride improvments you are looking for.
Check out Global West
Hop
