Very Upset
  • Thread starter Thread starter sambo60
  • Start date Start date Mar 7, 2009
sambo60
20
California
Mar 7, 2009
  • Mar 7, 2009
Well 2 months ago I put in a DFX centerforce clutch, my shop said it would be enough to hold my power. a few days ago I was on the freeway and I gun it in 5th and the engine just revs up, so I try it a few more times same thing. My shop suggested an RPS twin disc carbon clutch, which is around $2000, and the worst part is that they can't tune and install my new blower til they get the clutch in. What are my other options for clutches that can hold over 700 rwhp.
Thanks
oxfordgt
288
Clarksville, TN
Mar 7, 2009
  • Mar 7, 2009
My spec stage 1 clutch is holding my power just fine.
N
Nitrous03GT
17
  • Mar 7, 2009
did you follow the break-in period restrictions? CF clutches are good, but are touchy when it comes to break-in, if you dont follow it exactly how it says they will go to junk fast.
LaserSVT
3,548
233
Mar 7, 2009
  • Mar 7, 2009
I have a DFX on my Cobra and have no slipping issues in any gear at any throttle. Clustch has been in it for 30K+ miles
bhuff30
6,037
35
129
Olathe KS
Mar 7, 2009
  • Mar 7, 2009
Are you certain everything is adjusted properly to completely engage the clutch? It would be worth a check before forking out the money for a different clutch setup.
D
darkside03gt
851
Sacramento CA
Mar 7, 2009
  • Mar 7, 2009
make sure its adjusted properly first. If it is indeed bad I would get some kind of twin disc
BlownStangGT
REPEAT
3,860
Lancaster, PA
Mar 7, 2009
  • Mar 7, 2009
Well laying into it in 5th probably isnt the best thing......I have a McLeod Street Twin Disc Clutch which are rated to 800
Mcleod 96-98 Mustang RST 10.5 Street Twin Disc Clutch 10 Spline [6913-03] : Lethal Performance, Performance parts for Ford Mustangs
They are stiff as a mofo though
sambo60
20
California
Mar 7, 2009
  • Mar 7, 2009
yeah i broke it in properly, never launched it just mostly 2nd and 3rd gear pulls. I had my shop check everything, and its all adjusted properly. I'm looking for something that is very streetable that can hold the power, and i drove another car with the RPS clutch and it felt close to stock.
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Mar 7, 2009
  • Mar 7, 2009
how much power are you making?
sambo60
20
California
Mar 7, 2009
#10
  • Mar 7, 2009
  • #10
right under 600 at the wheels. but im putting a new blower on so i need a clutch capable of over 700 rwhp.
joshjwc9
1,095
17
39
Palm Harbor, FL
Mar 7, 2009
#11
  • Mar 7, 2009
  • #11
Spec Sells their Stage 5 which is rated up to like 800 ft lbs or more, the disk is sintered iron and is totally an on/off clutch. I know someone who has a 650rwhp Termi without any problems from the disk, he just keeps putting aftermarket cables in it though....
squeak93
2,352
419
164
Joplin, Missouri
Mar 9, 2009
#12
  • Mar 9, 2009
  • #12
The spec 5 is one nasty mofo. Have a friend with it in a 351 blower car, it snaped the input shaft of a 3550.. It had been holding his power quite well for a while now. He went through every other brand known before that. Best part is there is no break in time for it. Just bolt and hammer down.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 9, 2009
#13
  • Mar 9, 2009
  • #13
the spec 5 sucks to drive on the street. my buddy has that in his 900 hp cobra and it squeals and chatters constantly
i really like my spec stage 3+. it feels as smooth as factory and the pedal effort is not too heavy either. it has been holding my car with no problems for almost a year now
LaserSVT
3,548
233
Mar 9, 2009
#14
  • Mar 9, 2009
  • #14
Yeah the spec 5 is obnoxious on the street.
IMHO Centerforce is the best for street usage. Because of the counter weights they have the peddle effort is the same as stock yet the clamping force is so much greater. My 447 rwhp is just fine for my DFX
You could try stepping the size up to 11" and get the right flywheel, that may help. At least modulating the pedal will be easier
Also Centerforce has that dual clutch version for really high HP applications.
sambo60
20
California
Mar 9, 2009
#15
  • Mar 9, 2009
  • #15
Ok thanks guys for all the replies its been very helpful
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
M
  • mnky99
  • Sep 5, 2025
mnky99
M
