I get this really big vibration and it almost sounds like something is grinding in my tranny when i have the clutch disengaged (clutch pedal pushed in) and i rev the engine. any ideas?
I just had that replaced along with the clutch probably less than 3k miles ago. It was rattling really bad. This almost sounds like I'm grinding a gear
Is it doing this standing still or while you're moving? If the clutch pedal is pushed in I don't see how this could be a gear if you have the tranny in neutral AND the clutch dissengaged? Could be a worn driveshaft U-Joint if it's doing this while moving.
It's the grinding that puzzles me. Vibrations could come from tons of place (urethane engine or tranny mounts + cold weather) but grinding has to come from a part that's moving even when your clutch is dissengaged... Flywheel?
thanks for your help thus far, sorry i couldnt replay sooner.
I too am puzzled about the noise.
this vibration and noise happens both while moving and stationary, and while in gear and out of gear. the noise sounds like a grind, and when i hear the noise the shifter vibrates as well as if you're grinding a gear.
i will try to take a video with my phone. perhaps we can hear it.
Try checking your tranny's oil to see if there is presence of metal particules in it but I doubt it will be the case. So far, I'm leaning towards a clutch or flywheel problem. Did you take it back to whoever changed your clutch and TOB to see if he has any idea as to what's going on in there?
