  • SN95 4.6L Mustang Tech
Vibration/Rough Take-off
  • Thread starter Thread starter 617thmp
  • Start date Start date May 2, 2009
617thmp
  • May 2, 2009
I have a 2001 Bullitt and it has a very rough vibration that I can feel in the gearshift and the clutch pedal. The car is vibrates/shakes very bad when pulling out in 1st gear, but clears up after that. I am getting code p0131, p0135, P0141 with code reader which I know is 02 sensors, but it was doing it before the codes where thrown and my tech guy says that o2 sensors will not cause this type of miss/vibration. I looked for vacuum leaks and have found none. It has a new clutch, pressure plate, throwout bearing. Any suggestions would be appreciated.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
May 3, 2009
  • May 3, 2009
I'm betting flywheel. Did you get it resurfaced when you had the clutch done?
Tazzy
21
PA
May 4, 2009
  • May 4, 2009
+1 on the flywheel
bboylobo
130
Lancaster PA
May 5, 2009
  • May 5, 2009
i would def. double check the clutch installation. did you install it? if not have the person or shop resonsible doubel check their work.
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
May 5, 2009
  • May 5, 2009
i had the same problem...turned out to be the clutch... go check it!
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
