Vibration when letting the clutch out.
  • Thread starter Thread starter 6Stang7
  • Start date Start date Mar 7, 2004
6Stang7
1,470
Livermore, CA
Mar 7, 2004
  • Mar 7, 2004
When I let the clutch pedal out, it will vibrate until the pedal is all the way out. What causes this?
-Shaun
HISSIN50
34
129
Mar 7, 2004
  • Mar 7, 2004
rotating assembly - the flywheel , disc, or PP. can be warpage or funny wear.
Stump1000
495
Morristown Tn
Mar 7, 2004
  • Mar 7, 2004
Probably hot spots on the flywheel and pressure plate. Get a new clutch kit and have your flywheel resurfaced
C
charlesw6954
476
Mo
Mar 7, 2004
  • Mar 7, 2004
i think mine is doing what you are saying. my clutch is a fms clutch with low miles. i guess ill have to switch out clutches.
Stump1000
495
Morristown Tn
Mar 7, 2004
  • Mar 7, 2004
If its a new clutch... did you have the flywheel surfaced? You may be able to have the flywheel surfaced and use the fms clutch back. Lot of work to find out though
6Stang7
1,470
Livermore, CA
Mar 7, 2004
  • Mar 7, 2004
I never did this before. It worked fine with out a problem for the 200 miles I drove my car, then I pulled the tranny and clutch out while I was doing a T-5 swap on the 67. When I put it all back in I noticed that it vibrated when letting the clutch out. Now, I ma having a problem here were the clutch can't fully disengauged because the throw out bearing is too much, or the piviot ball is wrong, but could that still bet he cause? I know when my friend had the tranny rebuilt and stuff on his 88 Firebird, it had a problem with the car virbating when he let the clutch out. Could like the piliot bearing I bought be wrong, or the clutch not alligned correctly?
-Shaun
Stump1000
495
Morristown Tn
Mar 7, 2004
  • Mar 7, 2004
thats weird... the clutch has to be aligned properly or you wouldve never got the transmission all the way in. Does it feel like its chattering when you start letting the clutch out? Every time i've had that problem or i've ever seen it thats all it was.. the flywheel, disc or pp. I gues you have to drop the tranny again to see about the throwout bearing problem... so then you can look at the flywheel... see if it has blueish lookin spots on it
C
charlesw6954
476
Mo
Mar 7, 2004
  • Mar 7, 2004
well im going to be changing the rear main seal so ill get the flywheel resurfaced
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
WTB Wanted - Foxbody clutch pedal
  • TTSaleen
  • Aug 4, 2026
  • Want to Buy
Want to Buy Aug 6, 2026
General karthief
T
Drivetrain Take a look at this clutch pedal
  • TNmach1
  • Sep 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 18, 2026
TNmach1
T
