vibrations under acceleration and over 3k
  • Thread starter Thread starter Foxfan88
  • Start date Start date Jul 18, 2007
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jul 18, 2007
  • Jul 18, 2007
my car seems to get a vibrations i can feel in the shifter and in the seat. just cruising you cant feel it, but under WOT and once it gets over about 3000rpm it starts shaking. anything under 3k, like cruising in 4th or 5th at low rpm it rides smooth as ever, but like in 1st,2nd, 3rd and 4th gear under WOT it shakes and vibrates
just over 3k or so is when it virbrates.
have had any time to do any diagnostics but could you guys give me some ideas so i know where to start
the car has an Alum DS and its fairly new and i dont think thats the problem, i had previous vibrations that i fixed with the ALUM so i doubt thats it.
fox racer
577
Staten Island, NYC
Jul 19, 2007
  • Jul 19, 2007
Doesn't sound like a D/S problem, usually those come in at certain speeds at certain gears. Check the balancer first, make sure its snug and the rubber is still good. Could POSSIBLY be the bearing that the yoke of the D/S goes into in the tranny, but I doubt it. Just go over everything that rotates and make sure it didn't come loose.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Jul 19, 2007
  • Jul 19, 2007
the bearing that the yoke goes into?? could you elaborate, you sort of confused me.
i drove it today, and noticed that the vibrations come on about 3100-3200 and STOPS at like 3900 and it smooths out and the vibrations stop just in that 700-800 rpm range it vibrates.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Jul 19, 2007
  • Jul 19, 2007
Check your driveshaft bolts.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Jul 20, 2007
  • Jul 20, 2007
drove it again today and payed real close attention to it,
its not in that rpm range its more like focused at like 3500 rpm right in that area is when it vibrates. and it does just revving up with the clutch in. that tells me its probably the balancer.
4G-KDMP
935
CA
Jul 20, 2007
  • Jul 20, 2007
could be that you've lost a couple of wheel weights and that's causing your problem?
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Jul 20, 2007
  • Jul 20, 2007
my tires are out of balance but i can feel the vibration with the just sitting still revving it up. nothing to do with tires
i need to get tires balanced anyways lol
4G-KDMP
935
CA
Jul 20, 2007
  • Jul 20, 2007
oops.... my bad, i didn't catch that park of sitting still and revving it up
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
