vibrations/whining after gear and new clutch install
95 yellow 5 0
627
CT
only babied 100 miles so far since install. hear whining (almost whispery sound of metal spinning against metal) only in 3rd and 4th gear really when the throttle is first pressed and as the car speeds up it goes away. can't tell if it's coming from the rear or clutch.
it also vibrated pretty bad on the highway from 2700-3500 RPMS in 5th.
I am going to have the stock d/s put back on tomorrow and see if there is a difference... I'm thinking it will vibrate more but the mechanic says to try it. I went back to the machine shop to ask if the aluminum one they cut isnt balanced right and they said they'd fix it if it was the reason the car vibrated. what else can i check?
also on my last clutch i'd get a sharp squeak noise whenever i shifted fast/hard. tryin to turn left on a main st in traffic had to shift quick 1st to 2nd and it made that noise... any ideas to help me out are appreciated.
