  • 1994 - 1995 Specific Tech
Vortech ac line questions
  • Thread starter Thread starter BPA
  • Start date Start date Jun 15, 2005
BPA
159
S.F.
Jun 15, 2005
  • Jun 15, 2005
Vortech & ac line questions
Well the ac line is pretty much the last step i need to do to complete the V2 install. Who here has had there ac line or related parts crack from bending them? Ive decided to go with a custom ac line from a shop here in town so i dont have to deal with bending it.anyone else with custom lines in here? Id like to get a line that had some metal tubing but most places say they can fab one up using rubber.I may just go with the rubber hose setup even though it isnt what i want. Ive had a few friends who were sucessful bending the line and a few break the lines or tweak them bad. what are your guys exerience bending them? Seem line pretty hard pot metal to me..
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Jun 15, 2005
  • Jun 15, 2005
I broke mine the first time cause i didnt know what the hell I was doing. I bought another a/c hose and some info off stangnet and did it the second time succesfully.
S/CBlack95GT
2,018
Tampa Palms, FL
Jun 15, 2005
  • Jun 15, 2005
I bent mine with the help of my dad. It was pretty easy with two of us. One had to hold it while the other gently bent it along the entire length of the curve. You cant just grab ahold and bend it in one spot because that will cause it to split.
BPA
159
S.F.
Jun 16, 2005
  • Jun 16, 2005
im going to give what you say a try out shaun. I just get nervious bending ac lines.. I cant find a shop that will fab up a custom line with metal tubing in it only ones that will make a line out of hose and ive heard this isnt as good of an idea with all the pressure in the 134 system compaired to a steel or aluminum line. Tomarrow after work i will evac the ac system and get a buddy at work to hold the line while i bend and hopefully we will not break it in the process.Think disconecting the line completely would be of any benifit in bending? Brian
S/CBlack95GT
2,018
Tampa Palms, FL
Jun 16, 2005
  • Jun 16, 2005
Yea, bigtime. But then you have to recharge the system.
BPA
159
S.F.
Jun 16, 2005
  • Jun 16, 2005
not a problem i have an ac machine at work Ill just have to fugure out how much i need to bend . honestly it looks like it needs to move a good 3 or so inchs. thats a chit load
BPA
159
S.F.
Jun 16, 2005
  • Jun 16, 2005
bent the line. turned out not as bad as i thought it would. def helps to have a secound set of hands during the process though.
M
  • mnky99
  • Sep 5, 2025
mnky99
M
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
TB Injection Install (Aces Killshot)
  • LILCBRA
  • Feb 5, 2024
  • 4 5 6
23K
1974 - 1978 Mustang II Talk & Tech Dec 1, 2024
LILCBRA
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
