Vortech Owner--Oil Drain Line Question
94GTLaserRC
Squint as you approach, lest you be blinded by my
Im wondering if my slight oil leak is from the fitting into the drain pan, or a crack in the hose.
PROBLEM IS: The Vortech hose has the "knitty" material stuff on the outside, which makes it REALLY hard to see a cut.
Joe (Vib) said Vortech is the only place to get that EXACT hose.
QUESTION:
Is there any reason that we cant use a standard black hose from Pep Boys or Autozone to replace that hose???
I know Jose (st8stang036) uses one, and he said there are no problems with it..
Thanks
RC
