Vortech Owners...Drain Hose Question
94GTLaserRC
Squint as you approach, lest you be blinded by my
I just want to make sure..
The drain hose for the Vortech, is that 3/4" or 5/8" ?
I want to splice a heater hose from down below up into the stock hose higher up so I can check for leaks.
Also, HD does NOT have a double-sided 3/4" joining piece in metal...ONLY in Nylon...If the hose if 3/4", can I use a nylon part to join them??
If it is 5/8", I can get the metal joining piece, since HD DOES sell them..
Thanks
RC
Didn't I measure it for you before? You are in luck b/c the last time I measured it for you I had the blower off for a HG install and I just ripped mine off again last night. I will get you the measurement again. Stand by, Sir. :D
94SC50 said:
The hose is 2.5 in cir. and 1/2" (inside diameter)
:nice:
That hose is ONLY 1/2"??
I thought it was a 3/4 or 5/8 :shrug:
I dont feel like taking off the head unit to replace the ENTIRE hose, so for now, Im just gonna disconnect the stock hose from the oil pan stem, connect a piece of heater hose to it, then cut the stock one about 18" up above, and spice the new heater hose into it using the joiner piece and 2 clamps..If it is INDEED 1/2", I can get that joiner piece in metal.
Thanks for the effort JR..I need you to move back down here so you can help me with maintenance on my car..
RC
No problem dude anytime.
