  • SN95 4.6L Mustang Tech
Vortech V2-SQ S-trim or V1 S-trim Users come in
  • Thread starter Thread starter mat82284
  • Start date Start date Jan 5, 2009
  • 3
First Prev 2 of 3 Next Last
R
Roblu98
94
East Fallowfield, PA
Jan 6, 2009
#21
  • Jan 6, 2009
  • #21
mat82284 said:
I just ordered a Vortech V2-SQ S-trim and im just looking to break the 500hp mark right now, ideally i would like 550hp but 500 would be fine. I was hoping that there are a few users who have broken this with this unit then please fill in the table below as much as possible. Thanks in advance to anyone that takes the time to fill this out.
1) Supercharger Model - V2 SQ
2) Mustang Year- 99 Saleen
3) Supercharger Boost/pulley info- 3.25" 6# with alot of belt slip. 2.87" on its way!
4) Intercooled or not, or if using vortech aftercooler please specify.- Custom FMIC
5) Fuel mods, Stock Tank or cobra tank, what fuel pump/s and injectors?- 03 Cobra Tank and Pumps. 42lbs injectors.
6) Any engine mods, Heads, Cams, and so on.- Stock motor, BBK Long tube headers with Dr. Gas O/R X pipe.
7) Are you using the stock plastic intake or aftermarket, or new ford metal intake?
New PI intake with Alumium cross over.
8) What engine setup, forged, stroked, bored, and what compression ratio?-Stock. /QUOTE]
M
mat82284
889
#22
  • Jan 6, 2009
  • #22
SaleenGT2001 said:
the inline pump doesnt work with a returnless system
Wait are you serious, why is that? I guess im stuck with kenne bell boost a pump then im not getting cobra tanks any time soon, i just want something to satisfy my needs. I probably wont even hit boost but a couple times a week.
D
darkside03gt
851
Sacramento CA
Jan 6, 2009
#23
  • Jan 6, 2009
  • #23
mat82284 said:
The s trim is rated to 20psi, but im sure its not all that good up top. As for the tune I wouldnt ever go to force fed, I went to a company that has lots of experience under there belt and the car has been perfect, never had any issues at all, so i was going to go back to him.
BRG Motorcycle Racing Dyno Services
Lol i have been taunted by so many mustangs i just laugh when they try anything. I'm not a street racer and people always try to get me to race and i just look and then look away. I like my car and street racing would screw up insurance, as well as possible impounds and such. To much risk. Thats why i stick with the track. Now im worried though i might need a roll cage before i can go because if i break 11.50 im screwed at sac raceway.
Trust me you will NEVER see 20psi from that blower (maybe if you overspin the crap out of it) The most you will see is 16 and thats pushing it. Trust me on this one. I have a s-trim on my stang and have done tons of re-search on the blower.
+1 on the street racing. I have got on it here and there on back roads but have not street raced in a few years and have chosen to leave it behind due to possible impound/tickets and higher insurance.
D
darkside03gt
851
Sacramento CA
Jan 6, 2009
#24
  • Jan 6, 2009
  • #24
SaleenGT2001 said:
the t trim upgrade is only $300 more IIRC
T-trim upgrades are $600 not including new bearings and seels.
M
mat82284
889
#25
  • Jan 7, 2009
  • #25
yeah the Si is $300 upgrade. What color is your car? does it look like a bullet? I seen someone at sac city with mustang that sounded like it had a vortech in it, not sure if that was your or not.
M
mat82284
889
#26
  • Jan 7, 2009
  • #26
Anyone know where i can get a dual pump assembly from, or maybe i can modify my own to support 2 svt focus pumps?
D
darkside03gt
851
Sacramento CA
Jan 7, 2009
#27
  • Jan 7, 2009
  • #27
Nope wasnt me. My stang is black and is very plain looking. only apperance mods are a mach1 grill delet, shorty antenna and has been lowered about 1.5 inches. I havent even driven it since october.
98GTfromGA
291
Memphis
Jan 7, 2009
#28
  • Jan 7, 2009
  • #28
1) Supercharger Model Vortech V-2 S-trim
2) Mustang Year 1998
3) Supercharger Boost/pulley info 17lbs/2.80 ultragrip pulley
4) Intercooled or not, or if using vortech aftercooler please specify. custom A/A fmic and blowthrough conversion
5) Fuel mods, Stock Tank or cobra tank, what fuel pump/s and injectors? 60lb injectors, 255 intank, T-rex
6) Any engine mods, Heads, Cams, and so on. lightly ported PI heads, Comp XE274H cams, longtubes
7) Are you using the stock plastic intake or aftermarket, or new ford metal intake? plastic PI intake, trickflow plenum, 75mm TB
8) What engine setup, forged, stroked, bored, and what compression ratio?.020 over block, diamond pistons, modmax rods, cobra crank, arp head studs, 9.5 to 1 compression
This is a build that took six months and I just got the car started last week. Going to break in my clutch and dyno it at the end of January. Will let you know but I expect 550 plus at the wheels. And I know with that pulley I will be overspinning the blower if I go to 7000 so I probably will shift at 6500
98GTfromGA
291
Memphis
Jan 7, 2009
#29
  • Jan 7, 2009
  • #29
Here are some pics of the finished setup
If that doesn't work try click this thread ModularFords.com - View Single Post - Almost done with intercooler install....
stangJunkie04
44
Vernon, CT
Jan 8, 2009
#30
  • Jan 8, 2009
  • #30
1) Supercharger Model V1 S-Trim
2) Mustang Year 2004
3) Supercharger Boost/pulley info 2.8 rr pulley 14psi
4) Intercooled or not, or if using vortech aftercooler please specify. Paxton A/A FMIC w/NX nitrous i/c spray kit
5) Fuel mods, Stock Tank or cobra tank, what fuel pump/s and injectors? 03 cobra tank, dual svt focus pumps w/ kb BAP, 60lb inj
6) Any engine mods, Heads, Cams, and so on. MPH stage 3 heads, blower cams
7) Are you using the stock plastic intake or aftermarket, or new ford metal intake?prof products intake plenum & T/B
8) What engine setup, forged, stroked, bored, and what compression ratio?MPH Forged S/B
587rwhp 523tq on race gas spraying the I/C
Info on my combo above.
M
mat82284
889
#31
  • Jan 23, 2009
  • #31
I noticed your using the reichard racing 2.8 pulley, is that in 6 rib or 8? Are you getting any belt slip? I'm thinking of buying a 6 rib 2.8 pulley as well from them, where did you purchase it? There website didn't have direct ordering?
stangJunkie04
44
Vernon, CT
Jan 23, 2009
#32
  • Jan 23, 2009
  • #32
8 rib setup not too much belt slip once the car warms up.
M
mat82284
889
#33
  • Jan 23, 2009
  • #33
How much was your 8-rib setup, can you put one together or do you have to pay $500 for a complete kit. I was hoping to find one for $200-300 or less but if i cant get that ill probably just stick to my 6rib for now, then change it later.
stangJunkie04
44
Vernon, CT
Jan 23, 2009
#34
  • Jan 23, 2009
  • #34
589.00 with RR pulley
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 23, 2009
#35
  • Jan 23, 2009
  • #35
8 rib is worth the money!
98GTfromGA
291
Memphis
Jan 24, 2009
#36
  • Jan 24, 2009
  • #36
I'll have some dyno numbers in two weeks.
swapped v6
#37
  • Feb 6, 2010
  • #37
1) Supercharger Model vortech v2 s-trim
2) Mustang Year 2001
3) Supercharger Boost/pulley info 2.8 pulley 19lbs(with pre blower meth nozzle)
4) Intercooled or not, or if using vortech aftercooler please specify. no intercooler,..... dual nozzle snow meth system with two 10gph nozzles one b/f throttle body and one pre-blower
5) Fuel mods, Stock Tank or cobra tank, what fuel pump/s and injectors? return style, comp eng sump on stock tank, aeromotive a1000 pump -8an to rails and 6 back, aeromotive fpr, 60lb injectors
6) Any engine mods, Heads, Cams, and so on. 03-04 cobra bottom end, dss stg 4 heads, 1.5 mm oversize valves, anderson blower cams, bullit intake manifold, 8.8 to 1 compression
sct excaliber2 tuned by eric brooks at brooks speed in tifton ga.
602hp 521tq
swapped v6
#38
  • Feb 6, 2010
  • #38
i still have 6 rib and no slipping
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Feb 7, 2010
#39
  • Feb 7, 2010
  • #39
2) Mustang Year
Vortech SQ
99
3.12 pulley at 10psi with intercooler
procharger 2-core air to air intercooler
Stock fuel tank, 03-04 cobra pumps, 42# injectors
stock heads/cams/intake Boost pipe, Professional products plenum and 75mm TB, full exhaust including longtubes,
intake is the stock plastic one with the metal crossover
stock engine setup with a dyno tune
swapped v6
#40
  • Feb 7, 2010
  • #40
i got 19.94 out of my s trim and max pwr at about 6300
  • 3
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
For Sale 2004 Mustang GT w/ Vortech Ti Trim
  • 50Dreamer
  • Oct 28, 2023
2K
SN95 Mustangs For Sale (1994-04) Oct 28, 2023
50Dreamer
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
SOLD 1993 Mustang Cobra / 114K miles / Modified / Fort Lauderdale, Florida.
  • Naja
  • Oct 4, 2023
12K
Fox Body Mustangs For Sale (1979-93) Feb 26, 2025
Naja
R
For Sale Selling Supercharged 2000 Mustang GT Convertible - Michigan
  • robvas
  • Sep 8, 2021
2K
SN95 Mustangs For Sale (1994-04) Sep 8, 2021
robvas
R
