  • SN95 4.6L Mustang Tech
Vortech vs. KB. Pros & Cons
  • Thread starter Thread starter 95CobraStang
  • Start date Start date Jul 20, 2004
1 of 2 Next Last
95CobraStang
281
Chico, CA
Jul 20, 2004
  • Jul 20, 2004
Sorry, this is a little long.
It seems lately, that KB has been the blower of choice these days (unless all others just keep it quiet, that is). With that in mind, I want to weight out the positives and negatives of a Vortech and KB, as I am in the market for some forced induction.
Vortech over KB is good because:
- it seems a lot cheaper...is that so??
- it will respond to gears better. ie: it takes a while to build up full boost, so traction won't be at as hard to get AND the gears will put it in it's powerband perfectly
- you can push more boost through it.....eventually w/ a stronger motor
- the boost isn't always there for easy daily driving, so i would think it's easier on the motor.
KB over Vortech:
-much better torque curve!!!!
-more power!!
-power at almost any rpms
Basically, I'm trying to justify buying the Vortech over the KB b/c I can save a little money....But if it just does not make sense, then ill save up the extra. Would anyone choose the centri over the KB roots style? Keep in mind, this is a daily driver, and I won't be running anything but street tires.
Any feedback would be great...
Also, correct me if I'm wrong in any of my pros/cons, b/c I am still learning much, and they are only my opinions
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jul 20, 2004
  • Jul 20, 2004
If you plan on leaving the engine stock , FOR A LONG TIME , get the KB , if you know you are going to forge the bottom end later the vortech or novi2000 or procharger D1 are the way to go ..... the KB will out perform the others especially in the torque curve right out of the box , if you like low rpm torque get the KB ...... IMO..
Ryan02Stang
1,181
Arlington Heights, Illinois
Jul 20, 2004
  • Jul 20, 2004
I personally like the Vortech better. I feel you get a lot more for your money with that. Vortech eventually has more potential also.
kirkyg
3,568
Beaumont, TX
Jul 20, 2004
  • Jul 20, 2004
Perhaps you guys haven't heard of the 2.2L kit for the GT?
Twin screw imo is the best supercharger technology out there BUT it comes at a equal price. You nearly always get what you pay for.
kirkyg
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Jul 20, 2004
  • Jul 20, 2004
the KB won't neccesarily make more peak power than the Vortech. it depends on a number of factors. for one, the KB 9psi kit comes with an intercooler (one reason it's more expensive). i believe SmithAtlanta actually lost some peak power with the KB when he switched from the Vortech but he picked up a much flatter powerband. you can't go wrong with either blower. if you can, find people who have them and go for a ride. then decide which is best for you.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jul 20, 2004
  • Jul 20, 2004
kirkyg
2.2 IS STILL IN TESTING AND IS TOO MUCH FOR THE STOCK BOTTOM END....
kirkyg
3,568
Beaumont, TX
Jul 20, 2004
  • Jul 20, 2004
Do you have a problem 2002blgt? There is no need to yell at anyone i was just responding to someones post about the KB having no potential.
kirkyg
K
Ken01GTvert
175
Colorado
Jul 20, 2004
  • Jul 20, 2004
Other Vortech Pros:
More shops out there with experience to install and tune them
More guys have them on their machines and have good info in forums
Easier to prevent from going into boost when you don't want to
Runs cooler under the hood then the KB
Will work with strut tower braces (especially important for verts)
May be easier on your drivetrain since boost is not instantaneous
Other KB Pros:
Kit is complete with all parts necessary including injectors and pump booster
Kit comes with very thorough instructions with pics for everyday backyard mechanic
Kit replaces the stock lower intake manifold which has a tendency to crack under too much stress
IMO has more bling then Vortech (comparing polished versions)
Supposed to be quieter then centrifugals which makes it stealthy
Pure fun factor
I'm tempted to just flip a coin to make my decision.
Y
YellowJacketGT
108
  • Jul 20, 2004
I have had both on the same car. Built , stock heads, headers, 42#, 90mm MAF.
14# Vortech (441rwh/392TQ).
KB #14 (450rwh/465TQ).
I reduced the problem of low end torque by upgrading to 410 gears.
Vortech easy to run at the track. Tires hook , slam gas, pop clutch hang on...
Reasons for changing: No good intake available. Tried Reichard. Helped upper end. Needed to rev high to take advantage. High pull was was cool. Since max boost only for a short time temperature was not an issue. Could take a trip down the track time after time with no cool down. no problems.
KB is best intake you can buy... Parts sold very close to KB purchase.
KB looks great, sounds great. Instant boost/hp is fantastic. Slam the gas, neck snaping power now.. Had to go with 295/35/18 BFG dr's . At least I got 2nd and third back. (Have not changed 410 gears yet)..
465TQ at 3000 all the way to almost 5000. Heck could not start on dyno below 3000 because of tire slipage...
Because max boost is extended, heat generated is interesting to get under control (14# boost issue. I suspect its not as much of an issue with 9psi).
Have not been to the track yet. Expect tire hook issues. Not sure I can run back to back. Need a cool down.
Take your pick both are a blast..
Ryan02Stang
1,181
Jul 20, 2004
#10
  • Jul 20, 2004
  • #10
kirkyg
2.2L KB requires a built motor. Also pricing will be A LOT I assume
neoclasiccl
3,043
Help I can't see !!!!!!
Jul 20, 2004
#11
  • Jul 20, 2004
  • #11
For a street driven car you can't go wrong with either one. But I have to say the better buy for a 400HP stock bottom end GT would have to be the 1.7ltr 9psi intercooled KB. against the same HP centrifical the KB will win everytime due to the flat torque curve. Torque wins races
01MustangGT
202
CA
Jul 20, 2004
#12
  • Jul 20, 2004
  • #12
i would say KB 9psi, if u wanna keep it stock for awhile cause' the low end torque is just unbelievable. i just have mine installed a week ago, and i already smoke one Z28 and one SS. for the street, KB is so fun. u can peel out from first up to third gear without even try.
look at the torque curve for KB
BTW, anyone has a Vortech 9 psi dyno sheet. if so, please post it here. i wanna see the torque curve compare to the KB
Screwed2V
1,255
Misery
Jul 20, 2004
#13
  • Jul 20, 2004
  • #13
I have also had the vortech and KB on the same car although with different combinations. The vortech made 437 rwhp/404 rwtq at 9 psi with a bullitt intake and exhaust mods where the KB made 485 rwhp/482 rwtq at 9 psi with ported heads and cams. I've had three vortechs and now a KB (with a second on the way ) on this car and I can say the vortechs are great blowers but if you like the feeling of having a big block under the hood, go with a twin screw. Here's my old S Trim graph.
Bullitt #3067
132
Ann Arbor, MI USA
Jul 20, 2004
#14
  • Jul 20, 2004
  • #14
I own a Bullitt. Is it worth replacing the Bullitt intake with the KB twin screw? Or, should I just slap a Vortec or Novi 2000 on there and be done with it?
What would you do if you had a Bullitt intake?
01MustangGT
202
CA
Jul 20, 2004
#15
  • Jul 20, 2004
  • #15
Try to sell the Bullitt intake to other Votech guys, and put that money for the KB9psi. you wont regret
V
V8MstngPwr
70
Rio Rancho, NM
Jul 20, 2004
#16
  • Jul 20, 2004
  • #16
What is KB's website? I can't find it. Thanks.
K
kbbullitt
In the Cockpit
Jul 20, 2004
#17
  • Jul 20, 2004
  • #17
I will be installing mine (KB) in the next week or so, just waiting for it to arrive. I haven't decided what I am going to do with the Bullitt intake yet. I kind of want to keep it for the nostalgia but if I were to decide to sell, how much would it go for?
K
kbbullitt
In the Cockpit
Jul 20, 2004
#18
  • Jul 20, 2004
  • #18
http://www.kennebell.net/
This is one of the most informative sites there is, check out the FAQ's section. There is some amazing information available for cunsumption. Enjoy.
1992 2.3LX
885
Ky
Jul 20, 2004
#19
  • Jul 20, 2004
  • #19
sorry to hijack a little here. but where does the procharger fit in the Vortech KB battle. I have a stock 96 vert that will be getting some minor mods that i want blown eventually. and am starting the research and saving now. so just curious.
01MustangGT
202
CA
Jul 20, 2004
#20
  • Jul 20, 2004
  • #20
kbbullitt said:
Iif I were to decide to sell, how much would it go for?
1000 bucks, i guess
1 of 2 Next Last
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
J
PCV system help for S/C
  • jay99914
  • Feb 16, 2025
SN95 4.6L Mustang Tech Sep 26, 2026
AngryH58
A
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
