Want more Boost!!!
  • Thread starter Thread starter Brsmustng93
  • Start date Start date Jun 15, 2008
Brsmustng93
29
  • Jun 15, 2008
Just wandering what would be the cheapest, and easiest way to get more boost out of my novi 1220 sl. Should I just go with a smaller supercharger pulley, or should I do the 8 inch crank pulley with the Power pipe. Looking for about 8-10 psi out of it. Thanks for the help
93 LX
3,081
Norwalk, CA.
Jun 15, 2008
  • Jun 15, 2008
you want the compressor to turn faster to increase boost. To do that increase the size of the compressor's pulley
just4bob50
504
Pa.
Jun 15, 2008
  • Jun 15, 2008
Im sure you meant to say decrease the size of the pulley.
A larger diameter crank pulley, smaller diameter blower pulley, or a combo of both will increase boost as long as you are already not at the CFM limits of the blower.
A power pipe will help out also ( more air in more air out )
My home made power pipe picked up a little over 1lb on an 8 lb set up.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jun 15, 2008
  • Jun 15, 2008
Decrease pulley size..or larger volume blower.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jun 15, 2008
  • Jun 15, 2008
i'd make the effort to change the crank pulley first. the bigger blower pulley the better, a larger pulley will have more belt contact and go a long way to reducing belt slip.... once you get the biggest crank pulley you can, then you will need to start downsizing the blower pulley...
1SickFox
  • Jun 15, 2008
I agree. I currently have a SC-trim that i'm trying to get 10lbs out of. Change the pulleys first, but a AFM powerpipe wouldn't hurt anything either! Good luck!
Brsmustng93
29
  • Jun 15, 2008
Thanks for the help guys, I guess I will go with the 8 inch renegade crank pulley and the afm power pipe for now. If I choose to in the future go with a smaller supercharger pulley what size would you guys go with, the stock pulley is a 3.80. Also anyone know the cheapest place to get an 8 inch crank pulley and power pipe??
Forced Induction Vortech bypass valve necessity
  • 92Rustang
  • Aug 28, 2024
Fox 5.0 Mustang Tech Sep 2, 2024
Cheapskate207
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
2K
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
  • dan50
  • Jul 18, 2026
dan50
