Engine Water hoses that feed throttle body
I stand corrected.
Reactions: Rdub6
I believe the coolant running through the plate between the TB and the upper intake is to cool the in coming exhaust gas from the EGR, no EGR no need for the hoses :banana:
There are many theories but nobody knows for sure, "Why the water, Ford?". :ninja:
Some say, it ties in with the dude that stalks teen campers and can only be identified by a hook that he wears for a hand. :hide:
That theory is interesting. Just wondering, why are those fittings/lines missing from the Corba intakes? I’m starting to wonder if I should just cap the water ports and eliminate the lines? While I don’t have a Corba level motor, just a plain TBird boat anchor, it would help to cleanup the overwhelming clutter of the engine bay vs a simple carb engine.
Cobra uppers do not require the EGR spacer coolant lines nor do they have provisions for them. The one barbed nipple on the front of the upper by the throttle body is vacuum and goes to the charcoal canister solenoid valve.
Equated to a Carb intake, the warm water heats up the intake during the warm up phase of start up...???
That is also one of the possible explanations.
Thing is: Water and coolant during startup can be below freezing. :shrug:
Still, the theory exists that it's something like a "heat riser" on OEM carb'd cars.
Reactions: limp
Yes, but it warms up fairly fast.... And maybe not so much for start up but for better driving characteristics as the car gets to full operation temp...
I would guess that sucking in some very cold air would kee;p the entire air intake area cold for quite a while and this would be a fast way to generate some warmth to it.... Just a guess here.....
