Water in the pipes
I thought it was kinda weird since my cobra doesn't do it and most of my other cars havent' done it either. When you start it up a little bit of water comes out, and when you start moving a bunch more comes rolling out the pipes.
Upon the initial start up, it's often just from condensation inside the exhaust from the last drive.
Actually its a little known fact that ford really puts v8's into all their mustangs, except on the 6 cyl. cars, they dont use a waterpump. The 2 extra cyl's actually pump the coolant, and under extended full throttle runs some of it leaks into the exhaust.
This is completely normal and there is nothing wrong with the car.
Of what I know and have read, the byproduct of catalyzation turns to steam before egressing the tailpipes. An O/R piped car will have a similar amount of water exit the tails (in the same conditions) as a catted one.
