Fox Water/meth Injection
  • Thread starter Thread starter Kpblownfox
  • Start date Start date Sep 13, 2016
First Prev 2 of 2
Kpblownfox
53
18
18
Maryland/Delaware
Sep 14, 2016
#21
  • Sep 14, 2016
  • #21
I'm running a GM style sensor about 4 inches before the throttle body
Sent from my iPhone using Tapatalk
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Sep 14, 2016
#22
  • Sep 14, 2016
  • #22
I moved mine to before the tb as well... 170* in #5 runner cruising now I see 110* under the same condition.
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Sep 14, 2016
#23
  • Sep 14, 2016
  • #23
My plan is to move it right before the tb as well at some point
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Sep 14, 2016
#24
  • Sep 14, 2016
  • #24
Looking at the data from @MikeH686 and comparing to your data is actually pretty interesting that the temps are relatively similar as measured in the runner on being non intercooled and the other being intercooled. even though Mike is having a tough day with his reading comprehension... LMFAO!
FWIW, my IAT sensor is in the elbow just past my throttle body. I would imagine the intake runner mounted sensor does pick up quite a bit of residual heat. The main reason for asking Jeff's input here is that it should be a very comparable situation to the OP with the one major difference being Jeff's car has a power pipe. I would recommend the OP looking towards the UPR boost pipe if looking for a cost effective way to get the air inlet into the fender.
Reactions: TOOLOW91
MikeH686
Mine is only two inches though.
2,843
1,753
184
Waldorf, MD
Sep 14, 2016
#25
  • Sep 14, 2016
  • #25
@84Ttop jeez nick way to beat up on my reading skillz. I'll let you know for sure Friday how the temps are when I run the car just got the trans back yesterday gonna throw it in this afternoon
Reactions: 84Ttop and TOOLOW91
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,953
5,831
213
Sep 14, 2016
#26
  • Sep 14, 2016
  • #26
I've been watching this thread. Seems like I should move mine, too. Anyone know what size the threads are on the IAT ?
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Sep 14, 2016
#27
  • Sep 14, 2016
  • #27
Good question.
Kpblownfox
53
18
18
Maryland/Delaware
Sep 14, 2016
#28
  • Sep 14, 2016
  • #28
I'm still debating on if I wanna go with upr or Anderson pipe or if I wanna get some tubing and just weld a tube up myself
MikeH686
2,843
1,753
184
Waldorf, MD
Sep 14, 2016
#29
  • Sep 14, 2016
  • #29
I believe it's 1/2" npt or 3/8" npt
Bullitt347
I have been doing it wrong this whole time
4,066
3,139
204
Middle of Maine
Sep 14, 2016
#30
  • Sep 14, 2016
  • #30
Why would you move the IAT sensor to someplace that does not register actual intake air temp? The sensor in the intake manifold just before the intake valve would give the more accurate reading of what the air temp is before it gets into the engine. There is a reason Ford put it there, don't you think? Moving the sensor to before the throttle body will only skew the temp reading to a number that is not what is actually going into the engine. The temp sensor will read what the temp of the air that is flowing past the sensor, not the temp of the intake manifold.
02 281 GT
Agreed...My wife has great Boobs
3,208
1,973
194
Cabot, AR
Sep 14, 2016
#31
  • Sep 14, 2016
  • #31
Oddly enough, Ford did move the IAT sensor to the intake tube before the throttle body in the '94-'95 5.0. The '94-'95 computers are different, however, I am not sure if they made any changes to the computer to compensate for the different IAT sensor location.
MikeH686
2,843
1,753
184
Waldorf, MD
Sep 14, 2016
#32
  • Sep 14, 2016
  • #32
You have to think the sensor threads into that manifold it doesn't have a gasket it seats against or anything so its probably getting hear soak from the manifold itself the outer ring of the air stream is probably that temp but interior is probably much cooler. I'm not sure I'm just thinking out loud at this point I would much rather have it in the tube as I feel that's more accurate
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Sep 14, 2016
#33
  • Sep 14, 2016
  • #33
And the newer cars used to 2 one at the throttle body or manifold and one in the MAF sensor. Even other manufacturers including Honda which almost always utilize a speed density take the reading just before the throttle body
In my case from data logs I realize that my mat sensor was only reading Heat soak. When I got into boost or on the throttle my intake temperatures would come down. Now when I get into boost on the throttle my intake temperatures go up
Bullitt347
4,066
3,139
204
Middle of Maine
Sep 14, 2016
#34
  • Sep 14, 2016
  • #34
New cars pretty much all have plastic intake manifolds nowadays, so alleged heat soak is not an issue. Ford has thousands of hours of data regarding air inlet temps. If heat soak was possible, it would be only during hot idle conditions and the corresponding data that has been gathered could easily transfer real intake air temp to the measured ambient temp data. Once any rpm is induced into the engine, the resulting increased air flow past the sensor would eliminate any "heat soak".
Farrell5.0
Not sure what "DP" means, but know's he likes it!
353
299
104
Vancouver, WA
Sep 14, 2016
#35
  • Sep 14, 2016
  • #35
As for intake temps, I don't know what mine are because I never checked. As for system failure, everything man made can fail, so I wouldn't really let that dictate your decision, the likely-hood is slim. I have the stage 2 snow performance kit, rear mounted with the 2 gallon tank with a level sensor. It was a pretty simple kit to install and testing it is simple, too. You don't HAVE to tune for it but, why wouldn't you take advantage of it? We trimmed the fuel up from the richen and added 4*, picked up 40whp.
I think it's neat.
Kpblownfox
53
18
18
Maryland/Delaware
Sep 14, 2016
#36
  • Sep 14, 2016
  • #36
I planned on wiring in a fail safe to pull timing if it stopped spraying. I personally know someone who melted down a piston because his water meth didn't come on till half way through a run. I'm not deterred but the chance of it failing like you said everything can fail
Reactions: Farrell5.0
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Sep 14, 2016
#37
  • Sep 14, 2016
  • #37
With an aluminum intake it is very possible. If you like I have dozens of datalogs to verify.
Bullitt347
4,066
3,139
204
Middle of Maine
Sep 14, 2016
#38
  • Sep 14, 2016
  • #38
The sensor itself does not heat soak per sae, the air might heat soak from the hot aluminum, but the thermister on the end on the IAT sensor certianly does not. There is not enough mass to last but a moment once the air flow in the runner is off idle. The air in the intake runner also does not really get a chance to heat soak one it is moving off idle. The sensor is not measuring the temp of the intake manifold, only the temp of the air moving through it.
First Prev 2 of 2
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
R
Fuel Throttle body fuel injection
  • Robertstang
  • Aug 28, 2023
4K
Fox 5.0 Mustang Tech Sep 5, 2023
2000xp8
