Water/meth Placement
I'm looking to install a water/meth kit soon to combat my 200+ degree AIT's. my question is where have you guys had the most success placing the nozzles? I have a GM style air temp sensor about half way up my charge pipe and I'm concerned about the water\meth affecting the senor. Any advice is appreciated
You can put the nozzle close to the throttle body. The instructions for the water meth kit should tell you how far from the throttle body it should be.
Problem I have is my air intake sensor is before my throttle body in the charge pipe so I have to spray before the sensor so I can actually see the change in temp and there for time for those temps. I'm just wondering if spraying the mixture that close to the temp sensor will give me false readings on temps
...Oh yeah. .... lol.. how's that coming along?
Either way the meth is going to skew the afr, best way to approach this is to set up table switching.
When the meth comes on use an input that can be configured for table switching. (Usually the input is pulled to ground) this way you can tune for meth on just this extra table.
Good luck let me know if you need help setting it up.
