Water pump and timing chain questions
95wanttobe
25
1. What is a good high volume water pump to run on the 302 Mustang, using the orginal timing cover. This will be the reverse rotation, I guess.
2. How much slack should there be in a new double roller timing chain set. Mine appears looser than it should be. Probably over 1/4 inch slack, maybe even 3/8"s. It's a new summit double roller. Thanks
