Water pump question
  • Thread starter Thread starter golf4283
  • Start date Start date Sep 23, 2008
golf4283
1,253
Orland Park, Illinois
Sep 23, 2008
  • Sep 23, 2008
So I'm installing my 5.0L into my car and I'm hearing that I may have a reverse flow water pump or something so I want to know how to identify a reverse flow waterpump versus a regular. Also does anyone have a diagram of how the serpentine belt should run? When I received the engine the belt was removed and i'm not sure how it should go.
D
D.Hearne
11,730
south louisiana
Sep 23, 2008
  • Sep 23, 2008
Without taking it off the motor and comparing it to a known std or reverse pump, there's really no way to tell I can think of. If it's a 79-85 reverse pump, the telltale will be the impeller blade direction. If it's an 86-93 reverse pump, the coolant ports are reversed as opposed to a std pump.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Sep 23, 2008
  • Sep 23, 2008
If you are running a serpentine setup or it came off of one and you are using it with v-belts now, it is reverse rotation. It you took the serpentine pump, changed the pully and are now using it with v-belts yer going to have trouble cooling the motor...
jb1dsl
566
Marianna, Fl.
Sep 24, 2008
  • Sep 24, 2008
If it had a serp setup originally does not mean it was a rev.rotation pump. Crown vics and others came with std rotation pumps and serpentine belts
D
D.Hearne
11,730
south louisiana
Sep 24, 2008
  • Sep 24, 2008
True, and the late 88-up aluminum pump looks exactly like the reverse pump from the outside.
golf4283
1,253
Sep 24, 2008
  • Sep 24, 2008
hmmm. So what do you guys suggest doing? I don't want to take this thing apart. I bought the engine and transmission as a combo and don't want to separate to check. Can I just run the engine up to operating temperature and see if it overheats? Then switch the belt and see which way works better?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Sep 24, 2008
  • Sep 24, 2008
I thought Ford went to all rev. rotation after the switched on the Mustang and went to a serpintine belt... good to know.
What car did the motor come out of originally and what year is it ?
golf4283
1,253
Sep 24, 2008
  • Sep 24, 2008
See that's a good question. It was pulled from a 5.0L mustang but the car was originally a 4cyl auto. It was replaced with a t-5 5.0L so I'm not sure. Any markings I can grab off the stuff to find out years?
D
D.Hearne
11,730
south louisiana
Sep 24, 2008
  • Sep 24, 2008
It's no big deal to pull the water pump. You can buy replacement gaskets individually. If you don't have a pump to compare it to, I have pics of the timing covers on my photobucket site of the std & rev. timing covers. Or try looking at the pump to see if it's got stock Ford engineering numbers cast into it. Post those and I or someone else can tell you what pump it is.
D
D.Hearne
11,730
south louisiana
Sep 24, 2008
#10
  • Sep 24, 2008
  • #10
The Vic serpentine setup, really isn't. It uses a serpentine style belt, only there's two belts instead of one. One runs the P/S, waterpump and Alternator, the other the A/C & Smog pump. This is a good setup to use if you want to run dual alternators or a belt driven supercharger without A/C. The P/S and Alternator are on the drivers side of the motor leaving the passenger side open for something else. I used this set on my 89 Ranger's 5.0 with a high volume iron factory pump, I used the late Vic pump on my 331 in the Comet (std volume aluminum pump)
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
coil pack bracket
  • SteveG94GT
  • Apr 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 11, 2026
SteveG94GT
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
