Water Pump - Standard or high volume?
Kevin - have you talked to Baskin about what it's doing? You may have a problem with the temp sensor or location...
Does it run at 180F under cruise - in other words - when you're moving quickly enough to move enough air across the rad to not require the fans?
Thank you for the response Michael. I have tried two sensors... the first one I kind of destroyed trying to relocate it thinking it was a location problem initially. It's currently is 1.5-2 inches to the side of the bottom hose snug in the fins. I have yet to install the fan indicator light so I know exactly what my fan is doing at the moment but I will do that today. As for temp, I will have to get back about that tomorrow. I have gotten in the habit of manually switching the fan onto full for city driving to compensate. I have the jumper set for UD pullies so the fan is technically never off. I will tool around town to see what is happening. Freeway driving is just under 180 for sure though.
Kevin
If freeway is 180 -- then you know your t'stat and rad are doing their job. The challenge is likely with air movement at lower speeds. What temp do you have the fan set for?
I run a 180 and fan set at 187F. And that's exactly where it runs between. 187F in traffic cooling to 180 as I speed up and the fan goes off.
