I could use a little help here. I am putting a 5.0 motor out of a 95 in my 91GT. I have the block only for the 95 with the stock balancer, water pump, and timing chain cover. I know that the there is some difference in the water pump and timing chain cover between the two years. The problem is that I just purchased a high-flow counterclockwise water pump from Summit and I want to put it on the 95. Correct me if I am wrong but can I reuse the stock timing chain cover from the 91 to make it work on the 95? The other question I have is what harmonic balancer should I use, the 95 or the 91? The 95 motor has been sitting for a few years now and I don’t know if this will have any effect on it. Thanks for any input.
