Water Pumps
  • Thread starter Thread starter Bullitt
  • Start date Start date Feb 18, 2006
Bullitt
Packin' Heat
2,743
Houston, TX
Feb 18, 2006
  • Feb 18, 2006
ok, i've done a few engine rebuilds in the past, but most times had replaced the water pump with the rebuild. only time i didn't was on my Fox body and the pump leaked after i put it back on (but didn't before).
what's the deal with a water pump? i've heard that the seals go bad if they've been run and then are removed... is there any truth to this?
2nd Mustang
2,488
Southern California
Feb 18, 2006
  • Feb 18, 2006
I've moved water pumps from one motor to another without problems, but then the down time was just a few days.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Feb 18, 2006
  • Feb 18, 2006
I've heard this too and was told to keep the pump submerged in a pan of antifreeze to prevent the seals from drying out. Seems to work.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Feb 19, 2006
  • Feb 19, 2006
Yes and no. The seals can and do dry out, but the newer the pump, the longer it has to sit dry before anything goes bad. If you're concerned enough, submerge it in AF like dennis said.
Bullitt
Packin' Heat
2,743
Houston, TX
Feb 19, 2006
  • Feb 19, 2006
thanks for the input. i've been told that if i just replace the backplate gasket that it'll be just fine.
69Rcode_Mach1
1,473
Salt Lake City, Utah
Feb 19, 2006
  • Feb 19, 2006
Weird I haven't had a problem with that yet.
D
D.Hearne
11,730
south louisiana
Feb 19, 2006
  • Feb 19, 2006
The pump on my "spare" 5.0 that I just reinstalled in my Ranger sat up for a year and a half and it's been fine so far. Never took it off the motor but did drain the coolant from it.
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
9
New from northern MN
  • 91firecracker
  • Apr 19, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 19, 2026
Fox Water pump
  • JD1964
  • Jun 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2025
General karthief
