KAWMAN2 Member Aug 9, 2022 65 6 18 32962 Mar 24, 2026 #1 Mar 24, 2026 #1 Replacing water pump running a little hot any particular brabnd
JD1964 there is enough sticking out to grab on to 15 Year Member Jun 28, 2013 3,637 1,658 194 Maryland Mar 24, 2026 #2 Mar 24, 2026 #2 I have this one in the box and preparing to install https://www.summitracing.com/parts/tff-1594n?seid=srese1&gclid=EAIaIQobChMIkdjm1KO5kwMV_mlHAR37DBWlEAQYAiABEgLqDfD_BwE
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,550 21,721 234 Box behind Walmart Mar 24, 2026 #3 Mar 24, 2026 #3 KAWMAN2 said: Replacing water pump running a little hot any particular brabnd Click to expand... Need more info: Is your water pump leaking? How old is the radiator? When was the last time it was flushed? Are you using the OEM mechanical fan? Have you tested the fan clutch? Do you still have the OEM chin spoiler on the car? Reactions: 86HO5.0
AeroCoupe lube between the nut and the face. I know my lubes Founding Member Oct 28, 2001 6,232 4,325 183 Claremore, OK Mar 24, 2026 #4 Mar 24, 2026 #4 Well well well….if isn’t the old “lack of Information” and “who gives a F what car we are working on” trick question.
RaggedGT Been here over a DECADE and still no CT Mod Dude Jul 20, 2014 4,766 3,224 203 Taylorsville ky Mar 25, 2026 #5 Mar 25, 2026 #5 I bet it’s a Mustang…. I dunno who the goto is anymore. The last one I bought came from Advance auto Reactions: General karthief
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,550 21,721 234 Box behind Walmart Mar 25, 2026 #6 Mar 25, 2026 #6 View: https://www.youtube.com/watch?v=bBw4lctXdNw
