Water Temp Gauge Sending unit
Lcarder
South Carolina
I asked this question in 4.6 talk, but nobody answered it. Maybe someone can help me in tech. Where would be the easiest location to install a water temp gauge sending unit on a 1999 GT if I want to keep the original stock sending unit unit feeding the dummy gauge in the dash? I am a novice at this and don't want to start removing fuel rails and drilling and tapping holes; I'm not ready for that yet. Please help.
it is pretty easy to use a tap and make a spot on the rear of the water neck that the sending unit will fit in. I had never tapped anything well there a keg once, and well anyway it was a piece of cake. then just run the sening wire any way you would like.
I would second drilling and tapping the t-stat housing. It's very simple, and you can get a decent tap and die set fairly cheap at places like Harbor Freight and other auto parts stores.
I'd recommend removing the t-stat housing while you're doing the work on it.
