water temp(what should it be?)
  • Thread starter Thread starter Marlboro_Man
  • Start date Start date Oct 13, 2005
M
Marlboro_Man
437
Houston, TX
Oct 13, 2005
  • Oct 13, 2005
Well i picked up my first 87 gt today!!!
It has alot of aftermarket gauges and one of which is the temp gauge. It reads anyhwere from 180-210 , mostly 180-190ish but a couple times it hit like 210.
What should it range from? Also what temp is overheating?
I'll post pics this weekend of my new gt!
9
90bronconate
124
Phoenix, AZ
Oct 13, 2005
  • Oct 13, 2005
well the coolant i use says with a 50/50 mix, 265* is what it protects to. so it depends on what your mixture is. (you can get a tool to measure it really cheap at a parts store)
M
Marlboro_Man
437
Houston, TX
Oct 13, 2005
  • Oct 13, 2005
Yeah i have one of those tools , i'll check the coolant tommorow.
But i was just wondering if the temp starts to get high , what is too high? That way i can shut it down and check it out. The car has an aftermarket alluminum radiator and is using two electric fans, one pushing and one pulling air.
Anthony85stang
43
Meriden, CT
Oct 13, 2005
  • Oct 13, 2005
id start worrying if it rose above 230
HISSIN50
34
129
Oct 13, 2005
  • Oct 13, 2005
I am with Anthony. The puter starts pulling timing at 226*. If it has iron heads, you have more room for heating up than with alum heads.
Personally I would not want to go over 220. But as a point of reference, the 94-94s (5.0) low speed fan does not even come on till 208 (high speed is in the high 220's).
Good luck and enjoy the new ride.
00-Saleen
588
Snohomish,WA
Oct 13, 2005
  • Oct 13, 2005
My car Overheated at 250. 180-200 Is Normal
M
Marlboro_Man
437
Houston, TX
Oct 13, 2005
  • Oct 13, 2005
Thanks for the replies guys.
HISSIN50
34
129
Oct 13, 2005
  • Oct 13, 2005
A notation for 00 Saleen's comments. 180-200 is normal if you have a 180 t-stat. STock is a a 195 stat, so shift those temps up accordingly (from a 180) if you have a stock rated stat.
00-Saleen
588
Snohomish,WA
Oct 14, 2005
  • Oct 14, 2005
Well what Thermostat should i have in my car? Its Relatively stock But it has a Flowcooler Radiator, Aluminum Water pump, and a Black Magic Electric Fan kit....
feifong
319
mesa
Oct 14, 2005
#10
  • Oct 14, 2005
  • #10
180-200 normal but when u shut the car off it can go to 210. 220-250 worry
HISSIN50
34
129
Oct 14, 2005
#11
  • Oct 14, 2005
  • #11
There is no one right answer. Do you drive the car in the winter and is winter cold where you are (I forgot to check your location)?
I (personally) dont recommend a given stat-rating as a blanket statement. Some guys run at 220 in traffic with a 160* stat, whereas someone else runs at 200* in traffic with a 195* stat. The entire system has to be evaluated and the stat (and/or component upgrading) is chosen accordingly.
It sounds like your cooling system is stout. If a 195 stat keeps you cool enough (205-210*F or under, etc) then stick with it. Otherwise, a 180 gives the system a little more time to reject heat. I will note that the higher -ated stat actually allows the cooling system to reject more heat than a 180 stat (the larger the temp delta, the more heat is rejected).
So just play it by ear. Most folks on here run either a 180 or 192/195/197 stat. 160s are frowned up and it sounds like you certainly would not want that.
I will recommend Mr Gasket t-stats if you decide to swap. They are balanced, open fully sooner and have a bleed hole. 10 bucks at speeds shops.
Good luck.
00-Saleen
588
Snohomish,WA
Oct 14, 2005
#12
  • Oct 14, 2005
  • #12
Well i have the 180 in and it Never sees 180 In any conditions, whether it s cold or not. I drive the car every day. Im in seattle, Wa, and its always cold....
HISSIN50
34
129
Oct 14, 2005
#13
  • Oct 14, 2005
  • #13
00, something is not right. No matter how cold it is, the stat will need to open eventually (I grew up in Seattle, and it is quite mild compared to folks who live in the snow belt). The way the stat works is that it will simply stay closed longer if it is cold outside (I recall teens being about as cold as it got up there). But the motor still creates heat and once it does, the stat opens (even if ever-so-briefly).
It sounds like your stat might be stuck open.
Good luck.
M
Marlboro_Man
437
Houston, TX
Oct 14, 2005
#14
  • Oct 14, 2005
  • #14
Well thanks for the replies guys, today i realized that one of the fans wasn't running because the ground wire had broke off.
It stayed at 180* for pretty much the rest of the day , then i got into some good old houston traffic and it jumped up to about 190-195* so i exited the freeway and shortly after it went back down.
M
marvizu
31
Henderson, NV
Oct 14, 2005
#15
  • Oct 14, 2005
  • #15
Since we are on the subject, My temp guage does not go over the 130 mark unless I run the A/C and I live in Las Vegas. When I run the A/C, the gauge will get up around the half way mark and start to smell hot. In the winter my guage doesn't even get to the 130 and the heater does not get warm. I know that stock guages are for crap but it sounds like I have other issues. What do you all think? Sorry, I didn't mean to hijack the thread.
Oh yeah, I replaced the radiator in July of last year.
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Oct 14, 2005
#16
  • Oct 14, 2005
  • #16
this is the great thing about living in canada, this time of year it sticks at 180 all the time even in rush hour traffic. aftermarket gauge too. in the summer i only seen 200* once and that was cause of construction and +35C weather
in the winter we have a hard time getting some cars up to 180*
i have been told 180-210 is "normal"
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
