water temp.
  • Thread starter Thread starter dastang2
  • Start date Start date Aug 24, 2004
dastang2
2,020
tx
Aug 24, 2004
  • Aug 24, 2004
well aint this some crap if i aint ever seen any. i took the 89 for a little testdrive with the new radiator fans. the other day it idled for over 30 minutes and stayed at 185. now going down the road it gets up to 231. i used fans off of different cars. not sure where one came from but it pulls a lot of air but is not shrouded. the other one came from an 82 subaru wagon and it is shrouded. it too pulls a lot of air. i could not fit the stock shroud over both of them like i wanted too.now i have a little 90 f150's radiator. it is the same width as the stock mustang one but it is longer. i did have a 3 core from an 82 truck but it broke and this is the only one i have for now. the block is bored 0.60 over and i know i asked for it. i have no thermo now since the small radiator install. i know averheating is 270 and i am not that worried but would a 2 core aluminum radiator help me lower the temps. what else can i do. i live in texas and it is very hot today
87'GTstang
1,025
  • Aug 24, 2004
Well if your car gets hot at highway speeds, signs always point to the radiator. Do plenty of flush jobs to first make sure you don't have a blockage in your system. Then check your radiator to see if any of the core busted (usually a discoloration like greenich in color on the fins). Than if it still doesn't solve the problem, go for a good aluminum radiator - they work VERY well. Also, 3 core aluminum radiators are generally not needed because these things cool that good.
dastang2
2,020
tx
Aug 24, 2004
  • Aug 24, 2004
cool, does that water wetter stuff really drop the temps.
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
Engine Which cooling part first?
  • Dontknowchit
  • May 8, 2025
Fox 5.0 Mustang Tech May 15, 2025
90trunk
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
