  • 1994 - 1995 Specific Tech
Water Temp
  • Thread starter Thread starter sage2k
  • Start date Start date Oct 8, 2005
sage2k
645
Baton Rouge, LA
Oct 8, 2005
  • Oct 8, 2005
I was going 60mph on the interstate and my car wasnt even getting to the N in NORMAL on my temp gauge...i drove for about an hour.
So the temp was pretty low.
But soon as I got off the interstate and idle'd at a red light it went to normal temp at half gauge.
What ya think?
95COBRA241
339
Delray Beach, FL
Oct 8, 2005
  • Oct 8, 2005
Never trust those stock dash gauges. My does the same thing daily. sometimes the temp is pegged all the way to the left. I know the engine is warm cause the hood is warm. Its probably a bad temp sensor.
rgs
124
Vancouver, Canada
Oct 8, 2005
  • Oct 8, 2005
because when you are cruising @ 60mph on the highway your engine like isnt working @ all. therefore it stays cooler. the same thing happens to me, when cruising at a consistent pace for a substantial amount of time your temperature will drop. and once you start stopping and going it will rise up into the normal range.
sage2k
645
Baton Rouge, LA
Oct 8, 2005
  • Oct 8, 2005
well yeah but i mean it doesnt even get to the N in normal, but within 15 seconds of idling it goes half way on the gauge, how can i check the sensor or where is it located?
rgs
124
Vancouver, Canada
Oct 8, 2005
  • Oct 8, 2005
k well mine doesnt even get to N when on the highway, especially now since it's getting colder outside. but if you're telling the truth about it heating up after 15 seconds of idling, then i would say something is wrong. check your thermostat, might be time for a new one
18mustangs
533
Virginia Beach, VA
Oct 8, 2005
  • Oct 8, 2005
What ya think?
That's perfectly normal as the car is cooled much more efficiently on the highway becauss you're at a higher speed with much more air running across your radiator for a longer time. Go in town and the temp will rise as it's stop and go and you're spending a lot less time with air continuously moving across the radiator. You didn't list where you are, but up north it's getting cooler so that makes a difference too. After I put my fluidyne and 180* t-stat in my car did like you described in the 100* Texas heat.
Tim
dstanggt50
1,316
Woodinville, WA
Oct 8, 2005
  • Oct 8, 2005
I would think its a combination of not so accurate factory gauges, and the highway vs stop and go traffic. Mine will act similar, always cooler on the highway, but I usually in between the N and O of the guage on the highway, and closer to the middle in stop and go traffic. Might want to get a new ect to see if that helps.
Starman
78
  • Oct 8, 2005
Also check and make sure your fan is working. There was a recall a few years back where the fans would draw too much current and burn out
95COBRA241
339
Delray Beach, FL
Oct 8, 2005
  • Oct 8, 2005
What was it doing before? There is no way that with a 180* or 195* thermostat that the needle on the temp h=gauge would not reach the N in N-O-R-M-A-L. Something is wrong with the gauge or the sensor, or least likely you running w/o a stat.
sage2k
645
Baton Rouge, LA
Oct 8, 2005
#10
  • Oct 8, 2005
  • #10
well it used to be around the R-M in normal on the interstate sometimes higher close to A
im in louisiana, still hot but a cold front hit so it was slightly cooler, maybe in the mid 60s when i was driving, yea i understand temps should be lower in cooler weather but it seems excessively cooler and a short idle will bring temp to middle of the gauge. I was thinking of buying some new gauges like a temp and tach for better accuracy. Know any good deals on these tachs? preferable small ones i can mount in the clock gauge pod i see on ebay, i think 2 1/16th size
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Progress Thread Sask84gt's 84 GT - Questions and Progress Thread
  • Sask84gt
  • Oct 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
Sask84gt
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
