Forced Induction Water to air intercooler
nickstone302
69
Maine
Hi guys, I was informed by my dyno guy that 10psi on a stock block with no intercooler is a bad idea. Anybody have any information on water to air intercoolers and know or any good manufacturers.
Sent from my Desire HD using Tapatalk 2
The nice thing about air to water, is that air to water intercooling has an efficiency rating of 4:1 while air to air can at best achieve only a 1:1 efficiency ratio. In other words, if the ambient air temp is 100 degrees F. the coldest the air inlet charge can be is 100 degrees F. While a water to air system can actually make the air charge temp below ambient. The trick is fabricating a air to water system for a pushrod engine that is simple and cost effective.
Pinging is bad regardless of how the engine is built and you can split the stock block without an intercooler. I would be more inclined to plumb a water injection system instead of an air/liquid intercooler.
Additionally, do the rest of us a favor and disable the Tapatalk signature in your phone.
