Also Push rod engines usually are the ones that throw rods from what I've seen.No Modular blocks are actually a better built engine everything equal. Stock modulars are just not forgiving to detonation due to their week internals. This is why you can have a piston break and you would not even know until oil works past the piston into the heads. The blocks for modulars rarely get damaged where as push rods will shoot the rods through the bottom of the block on a regular basis.OinkAodeOink said:So would you say the mod motor's are less forgiving then say a 92-up 5.0?
The 5.0's have the hyper pistons, cheap rods and cast cranks, but seem to take a a decent amount of abuse, and usually the block is first to go.
I would say yes….as a whole, the modular engine is less forgiving for the most part than the OHV. The 5.0L has the same cheap hypereutectic pistons, but their design is a lot beefier and carry a lot more meat around the upper ring landings, where the mod motors tend to go. The rods in a 5.0L are actually pretty good. Much better in comparison than the spindly toothpicks that the modular engines are equipped with. The problem with the mod motors, are that once the piston goes, it usually takes the rod with it. As far as the crank….both the SOHC and OHV engines use a cast nodular crank. The SOHC crank just happens to be a little beefier and recessed deeper into the block adding to its strength in comparison.OinkAodeOink said:So would you say the mod motor's are less forgiving then say a 92-up 5.0?
jimfitzgerald said:Cost effective? Is any of this cost effective? If you're doing the internals, you might as we get a Cobra crank while you're at it.
