History: driving the other day one of the 2 hard coolant lines on top of the lower intake manifold blew. This made all my coolant go all over the place and blow a head gasket. All of that is fixed now but my car won’t start. I have been following the wont start checklist but I fall somewhere in the middle, I have spark but not strong enough to do anything this is what I have done.
Check for spark- I have a very weak spark at the coil but not at the plugs … coil is new
I have also loosened the timing hold down and turning the distributor makes the fuel pump turn on
Check for fuel – I have 12v signal at the injectors and fuel pump has power
CODES- doing a KOEO test I get no codes at all?? Does this mean the computer is bad?
The thing that confuses me is the weak spark of the coil… you can barely see the spark of the plug gapped 54
