Weak spring pulling rearend off center?
  • Thread starter Thread starter Booksix
  • Start date Start date Jan 14, 2008
Booksix
179
San Diego, CA
Jan 14, 2008
  • Jan 14, 2008
I have a rear spring so weak that my ride height adjuster on that side needs to be raised about 3" to get it even with the other side of the car. Do you guys think this could cause my rearend to be pushed off center (its off by about 1/2" - drivers side, where the weak spring is)?
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Jan 14, 2008
  • Jan 14, 2008
inspect the torque boxes
Booksix
179
San Diego, CA
Jan 14, 2008
  • Jan 14, 2008
What am I looking for? Will it be pretty obvious? They've looked solid up til now, never looked too close though...
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Jan 14, 2008
  • Jan 14, 2008
also check all the bushings in the control arms. upper and lower. and if your torque baxes are torn or rusted it will be very visably noticable.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Jan 14, 2008
  • Jan 14, 2008
Look for obvious tearing.
Basically if you see something that looks odd...chances are you've found a prob
Booksix
179
San Diego, CA
Jan 14, 2008
  • Jan 14, 2008
oh, ok, well I know for sure there is no rust or tearing. They are rock solid in that way. So does anyone think the spring could cause the offset in the rearend?
I didn't want to say this until I got some answers on the spring (because the rear-end was offset before and after the inncident) but I had someone try to jack my wheels a couple weeks ago and lost the left rear at 75 on the freeway (and no, I could tell I was missing lug nuts - not until about 3 seconds before the big bang). After that I noticed the offset more, but I think it was just because I was looking closer then (I had to inspect before calling the insurance company).
Anyway, I tried measuring the offset, but I'm having a hard time finding good reference points to find the cars center; especially in a way that will allow me to accurately transfer that to the rear-end and measure the offset. Also, that doesn't really help me find the problem. Maybe control arms bent? If so, how do I figure that out (they look fine visually)?... spring or control arms?!?
NKau
1,346
Jefferson, WI
Jan 14, 2008
  • Jan 14, 2008
Take a closer look at the torque boxes and control arms. There is no other way your rearend is going to get that off-center.......
Maryland Stang
1,656
30
39
Greenville, NC
Jan 15, 2008
  • Jan 15, 2008
It is impossible to measure anything accurately if you have known worn parts like a weak spring. Control arms, axles, shocks and the like don't move in a verticle plane. As the back of the car goes up and down the axle changes position relative to the rest of the car.
Fix all known problems before going any further.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Jan 15, 2008
  • Jan 15, 2008
I doubt a spring would physically move the rear that much off center
Booksix
179
San Diego, CA
Jan 15, 2008
#10
  • Jan 15, 2008
  • #10
Ok, thanks. I was planning on getting MM arms anyway (removing quads to make way for my 10.5's ) so I guess I'll change my springs and arms and see what happens from there.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 8:51 AM
Rdub6
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Yesterday at 10:26 PM
AeroCoupe
