Weight balance on a classic stang
1969mach1351 is more accurate at 58/42 than 65/35. The only car I know of that has that kind of weight balance is the Mini Cooper @ 63/37.
You can adjust the front/rear by a point by moving the battery to the trunk. Having the extra weight back there doesn't hurt off line traction either. Aluminum heads can shave some more. If you have A/C with an old iron compressor, you can shave 20+ pounds by switching to a lighter aluminum sandend compressor. Another advantage to shedding the pounds is for every 100 pounds you reduce in weight, it shaves ~1/10 sec. of your 1/4 mi. times.
Well, for a more concrete answer... I went to a truck weigh station, and they weighed each wheel. With me and a friend in the car, as well as all my tools/jack/etc (probably at least 50 lbs) worth of stuff in the trunk, and half a tank of gas, my front wheel weighed 1840 and my rear weighed 1400. so thats about 57/43 doing the calculations in my head. Without the junk in back, its a little worse.
my '67 fastback weighed in at 53/47 (total weight of 3300) on a set of LongAcre scales. this is with aluminum heads and radiator, with the battery in the trunk.
for comparison, a Fox Body mustang runs about 60/40!
To get it closer to 50/50 you have to use aluminum heads, intake, radiator, shorty headers will help over the heavy stock manifolds, do a battery relocation lose some weight, and you probably still won't be close. You can also try relocating the engine back or just throw a bunch of bricks inthe trunk. :rlaugh:
That's getting pretty good there. Did you do anything else to save weight? I'm thinking a fiberglass R model cowl without the bumber and a glass hood should help too. I bought Summits battery relocation kit and just didn't like it. The box is way too big and the slightest smell of gas in the trunk area has me worried. I have a friend that knows of a battery that is supposed to be strong enough for our purpose yet small and light. So I may go that route and keep the battery up front for now. As long as it's strong enough to run an electric fan that I'd like to convert to. I'll move the battery if I ever win the lottery to afford one of those nice race gas tanks that drop in. :)
Ronstang said:
I haven't had a chance to weigh one yet but I move the engine/tranny back 1/2" on most of the Mustangs I work on now.....it should have an impact but I'm not sure of the magnitude.
Do you have any details available about what you do to accomplish this? Sounds like a fun project! I'm sure there's a noticeable impact. :nice:
I guess everyone has proved the factory numbers are pretty close. Most stuff I've read put the 65-66 at 54/46. Historic is doing what nascar does for adjusting their weight dist. You can move the distribution around some by playing with spring rates and ride height at the corners. This is also what ricers get to do with their fancy coil-over spring/shock setups, they can corner weight the car and adjust each corner to balance the distribution, within a range anyway.
I have a stack of sheets I down loaded and printed out from another forum regarding suspension measurements and data. One of the sheets is the static weight measurements of a 65 Fastback. Shows measurements were 55% front/ 45% rear. If anyone wants, I can scan it and post a link
