Hello everyone. I have a 1991 automatic mustang gt. I've noticed when the transmission has completely warmed-up, it makes a weird sound just as it is about to shift from 2nd into 3rd gear. It is like a brief squeal sound. Sounds like beeeeez. Doesn't sound like a metallic grinding noise and the transmission does not slip. The fluid also looks and smells good. The fluid level is also okay. I also floored it once and instead of shifting at the factory 4700 rpm shift point (first to second) it shifted at 3500 rpms. The car has 3.73 gears, but I don't think it is suppose to affect full throttle shift points. Other than that, the shifts feel good and not sluggish. I've checked the TV cable and it is set at a point which there is no slack and no tension. I'm going to take the car to a transmission specialist tomorrow, but I would like to hear other opinions also.
Thank you,
Alexi
Thank you,
Alexi
It is a unique sound coming from underneath the floor.
