Weird charging issue
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Feb 3, 2011
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Feb 3, 2011
  • Feb 3, 2011
Ok on my 89 it has the 3G conversion,and battery is in the trunk.I dont drive it often.So i have noticed that when i drive it the gauge reads fine (1/2 way) but then sometimes when i go to start it it cranks over very slow almost to where it barly barly starts, like the rrr......rrr.....rrr then it fires.The gauge reads good still and alls fine.This usually happens after i drive it.If it sits for a few hours or more it starts just fine.Any ideas?It is a new battery but since it sits for periods at a time between driving it could the battery just be dead?But then that dosent make sence cause if it sits it usually starts fine!Just when i do drive it it cranks over very slowly!BUT also like i said the gauge reads fine,even though it cranks very slowly.........Now another question diffrent stang.It's my DD 4 banger.I washed under the hood yesturday,well now the gauge reads low volts.The lights are as normal,it starts as normal everything electrical is as normal.Plus the stock alt is less then a year old!It has never done this untill i washed under the hood.So could it be just water got in somewhere?I'm gonna give it a few days and see how it goes.peace
john
Admin Dude
Jan 4, 1985
43,535
21,705
234
Box behind Walmart
Feb 3, 2011
  • Feb 3, 2011
Mustang number 1 = Likely corroded battery terminals, wiring, or connector.
I recently had these same sysmptoms.... thought that either the battery or alt was going bad. I'd shut down the car and it would start all slow or not at all until I'd waited some minutes before trying again. It was lame... I cleaned up the battery terminals and all was good.
Mustang number 2 = I like your current plan
HISSIN50
34
129
Feb 3, 2011
  • Feb 3, 2011
Do you have LT's?
Have you driven the 4 banger since it was washed?
The belt might have simply been slipping after the wash.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Feb 3, 2011
  • Feb 3, 2011
HISSIN50 said:
Do you have LT's?
No it's turbo'd but it did this even before the turbo and yes when it was N/A it had L/T's.Yes i have been driving the DD since i have washed it.peace
john
ID89GT
1,659
18
49
Spokane Valley, WA
Feb 3, 2011
  • Feb 3, 2011
Heat soaked starter?
stykthyn
5,232
2,652
223
gainesville
Feb 3, 2011
  • Feb 3, 2011
Mustang 1) had this prob on my car. Starter was the issue. Tested fine when I took it to the part store so I cleaned all the grounds ran new cables and leads and no change. For giggles I replaced the starter and no more hard starts.
9
90stang5speed
582
Columbus Ga
Feb 3, 2011
  • Feb 3, 2011
thats the down side to testing a starter at the parts store on the bench. there is no engine for the starter to have to work to turn. some parts stores can test to see how many amps the starter pulls while on the vehicle.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Feb 3, 2011
  • Feb 3, 2011
this could be???I will get a starter heat shield blanket
This is a thought as well? As far as the DD ithe alt took a **** just that fast!Or from washing the engine off?Weird cause i wash the engine off every ten times or so when i wash the rest of the car.. peace
john
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Feb 3, 2011
  • Feb 3, 2011
I bought a f150 with a 460 in it. When it was cold it would fire right up. When it would warm up it would crank hard and not want to start...the timing was way off. Just a thought.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Feb 4, 2011
#10
  • Feb 4, 2011
  • #10
Thats a good thought but it's always done this weather this tune or the N/A tune.peace
john
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Feb 4, 2011
#11
  • Feb 4, 2011
  • #11
I do still have some DEI header wrap left over.Although it is used to keep the heat in in headers...would it be ok to wrap the starter in it to keep the heat off it?peace
john
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
K
1995 GT Random Starting Issue
  • kfvintx
  • Jun 24, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2024
CAMTWO1070
K
Electrical charging issue
  • knucklehead11
  • Jul 15, 2024
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 16, 2024
Mcmahst
Electrical Intermittent battery/charging issue
  • Grn92LX
  • May 7, 2023
2K
Fox 5.0 Mustang Tech Jun 28, 2023
Imatk
I
