Electrical Weird door wiring issues
Dakar09
24
25
23
Dedham, MA
So I've read a lot about the wiring pathways and issues with power door locks and windows on ye olde fox bodies. But I'm not sure what could be causing my issues at this point (outlined below).
Power locks no work on either side:
Fuse good
Passenger door won't lock with key, suspect bad lock actuator.
Power to switch, no power coming out of driver's switch
Replaced switch, power out of driver's switch, but no work on either side. Ordered new actuators off Amazon and will do the rig setup people shared in another thread
Power windows:
Both doors worked intermittently when I first got it a few months ago.
Then passenger window would only go up with driver's switch, but went down fine with either switch
Driver's door worked fine
Then neither window would work from either switch
Power to switch, not out.
Put new switches in,...
Fuse good
Power to switch and out of switch when pushed, dome light even dims when I push either switch (driver or passenger), so power to the motors is being supplied..
Driver's window still won't work, passenger window only works from driver's side switch now
I had the dash apart when I did the interior, so I suspect I may have jossled the plastic ignition switch (replacement on the way), but if that was the case, I'm assuming I wouldn't be getting power to the switches at all.
Tried jiggling the key and cycling ignition cylinder while holding the switches. No movemento. But I'll replace the switch and wiring anyway.
Next is pulling the door cards.
Any ideas from the experts?
Buy a cheap China knock off power probe, something like a p100 top diag for around $30 is fine, this will let you supply power and test the motors/ actuators before wasting money on other things. All these parts are old as dirt now so many are locked up, have broken bushings like in the windows motors are super common and can be fixed with some small 1/4-20 hex nuts for a quick hack to replace the plastic bushings or just plain busted, most of the switches will come back to life with a good cleaning of the contacts, almost all where dead simple copper contact switches.
The door power switches has its own jumper harness that runs along the kick panel and under the dash, your going to want to probe those connections to see where power stops, believe its a green 8 prong rectangle if I remember right on most year, harness wires are typically pink.
Reactions: Mcmahst and Dakar09
Check the connectors behind the kick panel (driver side first) as the door wires connect into the overall system there. I had an issue in those connectors a couple years ago with my fuel pump. What happened was the female pins in the connector had opened up over time and did not make constant and consistent contact with the associated male pins and would periodically lose contact and fuel pump would quit. I took a small screw driver and pried the two halves of the female pins toward the middle of the opening. It helped and 3/4 years later I don't get fuel pump glitches.
I just remembered I had to do that with the drive side power window switch connectors too.
Reactions: Dakar09
Update:
Pulled the door cards and hooked up the power tester.
Here is the wiring diagram I worked off of:
Fuses all intact. I assume the circuit breaker for the windows is intact, as well.
All switches are new.
Wiring is unmolested from what I can tell.
Pink wire to all switches is providing 12V
Ground tested good
Driver side LH switch had 12V out on both wires, no movement. I disconnected the harness and tried jumping directly to the window motor plug and got no movement. Assuming window motor is dead now.
Driver side RH switch works perfectly to open and close the passenger window.
Passenger side switch doesn't work at all. This is the one that confuses me, because the motor obviously works from the driver's side. There is a power draw when I push the switch (dome light dims) and 12V is present at the switch.
Power door locks....the actuators are VERY old (likely original). The driver's door is broken off of the locking, which is why I can use the key on that side. The passenger side is still attached and likely frozen. No movement on lock at all on that side. These will be replaced.
At this point, I'll probably get two new window motors, rebuild the tracks, and replace the door lock actuators. Still not sure what's happening at the passenger side.
If you want to jumper the door lock actuators( to test/cycle them), you have to do it at the connector in the kick panel (in the car, not on the door). In the kick panel, follow where the wires from the door go. You want the grey 8 or 10 pin connector. The door locks are on the one end - same and both sides of the car.
I usually test power windows with a cordless tool battery (18V in my case). Find the correct two wires at the door connectors and touch to positive and negative on the battery. Switch polarity to switch direction of movement.
