Weird Missfire
Brando5641
127
FT Gibson OK.
ok its a 1986 just put new intake gaskets and now i have 4 dead Cyl.
Im thinking its a standard firing order.
1-5-4-2-6-3-7-8
i have 1- -4- -6- -7-
no -5- -2- -3- -8
I wiggled the wires on the salt and pepper shakers and it didnt do anything, did i pull a ground off or somthing?
If i do the HO firing order it sounds like it is 180 out (pop's threw exaust)
Verify piston #1 is at the top (first cylinder on pass side), and stab the dist with the rotor pointing to #1.
Just need ot make sure you stab it in a location that allows you to rotate the dist enough to set timing correctly without hitting the intake.
