Weird RPM's Problem
  • Thread starter Thread starter savegoodautonfg
  • Start date Start date Nov 9, 2007
savegoodautonfg
1,085
  • Nov 9, 2007
Its actually realyl strange problem, and i cant figure it out. Well, when im driving in any gear but you dont notice it in first though, when i hit the gas harder then a little bit like the rpm's raise but its like the car is'nt catching when the rpm are going up. Its almost like when you are driving and you have your right foot on the gas and the left foot to just push the clutch down. LIke you are accelerating and you just tap the clutch adn the rpms raise and then you'll continue to accelerate. I hope you will understand what i'm talking about.
Thanks in advance.
-Nick
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 9, 2007
  • Nov 9, 2007
Sounds like a slipping clutch to me.
D
dec322
401
Bham AL
Nov 9, 2007
  • Nov 9, 2007
I agree. Sorry.
savegoodautonfg
1,085
  • Nov 10, 2007
What would cause this? What would cause a slipping clutch?
basically, if you punch the gas the rpm's rise and then the car would really slowley start to move quicker, and sometimes after a bit the car seemed like it would catch a little bit.
savegoodautonfg
1,085
  • Nov 10, 2007
It does it all the time to the point where i cant really move that fast at all. I have to let it gradually go. its really a pain in the ass. my check engine light flashes sometimes so im gonna run the codes today. but this clutch only has like 20,000 miles on it.
Disturbed90gt
portsmouth, va
Nov 10, 2007
  • Nov 10, 2007
it sounds like its time to replace the clutch honestly. once it starts slipping like that then its time to start looking for a new one
corvetteguy
71
  • Nov 10, 2007
The rubbing plates on the
clutch disk are worn down to
a point that it no longer grabs
hard enough.
Caused by age/use or racing.
If you were lucky it could
also be the adjustment is way to tight.....
savegoodautonfg
1,085
  • Nov 10, 2007
How would i adjust it? Stock clutch and all that clutch stuff is stock.
jammer84_03
468
  • Nov 10, 2007
need a firewall adjuster to adjust, if its still a stock clutch, and assuming its got alot of miles, time for a new unit
savegoodautonfg
1,085
#10
  • Nov 10, 2007
  • #10
HOw is this for a clutch?
http://cgi.ebay.com/ebaymotors/ws/e...m=280172249017&ssPageName=STRK:MEWA:IT&ih=018
F
Fox8950
247
Nov 10, 2007
#11
  • Nov 10, 2007
  • #11
I wouldn't advise running that or any other aftermarket clutch without getting rid of the old stock plastic quadrant. ESPECIALLY with an aftermarket clutch it starts to deflect and bend easy with just a little extra plate pressure, otherwise the king cobra clutch is a pretty safe bet with your setup.
savegoodautonfg
1,085
#12
  • Nov 11, 2007
  • #12
well im getting this also?
http://cgi.ebay.com/ebaymotors/ws/e...STRK:MEWA:IT&viewitem=&item=280170188333&rd=1
F
Fox8950
247
Nov 11, 2007
#13
  • Nov 11, 2007
  • #13
That'd do it .. I've heard some bad things about the adjustable cables but no personal experience with those here just had a firewall adjuster.
Fast63
717
#14
  • Nov 11, 2007
  • #14
I run the Heavy Duty clutch kit with stock quadrant and I have no problems, but I live in california where weather does not age parts very fast. You can also adjust the stock setup by pulling up on the clutch pedal and then operate it like normal, it is self adjusting. But it sounds liek you have bigger problems.
savegoodautonfg
1,085
#15
  • Nov 11, 2007
  • #15
anyone else hear anything good about the adjustable clutch cables?
and compared to the centforce clutch how is king cobra?
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
