Alright well I did everything perfect following Jrichkers diagram. I spliced the small wire in the power harness to the stator wire. I plugged in the smaller harness. Ran a 4g power cable to the alternator/battery side of the solenoid with a 125amp fuse in between. I also have a 4g ground from the engine. And I DID NOT put the negative on the positive and the positive on the negative so please dont say it.
I went to go connect the battery cables and when I put the ground on it was a big spark show. Not like the normal couple sparks that happen sometimes, but like alot of sparks, and it melted the top of the battery terminal. I am guessing this is not normal? Any ideas? Please help trying to get this car running.
The car ran fine just before the install. I dont have any amps or audio equipment besides a cd player, but I have a 2g positive cable running from the back to front. Should I get a 2g ground cable for the batter? I wonder why it didnt make a difference before. I didnt even try to start it I just touched it and it sparked up real bad and the terminal melted to the post.
