WEIRD timing issues!?!?
  • Thread starter Thread starter UnderdogGN
  • Start date Start date Jul 13, 2007
U
UnderdogGN
74
  • Jul 13, 2007
hi all, decided to check and set my timing the today and something is going on that is kind of weird...My car will only run and idle smooth/well with 20+ degrees of timing??? lol anything less will cause a terrible idle and cause it to shut off. Its been at set at this for a long time and there is no detonation so i think its fine but why are my numbers so far off? By the way its 20+ degrees according the stock timing pointer, but reads 0 degrees on my aftermarket ATI timing pointer. (a bit shorter than stock)
any ideas?
thanks in advance!
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Jul 13, 2007
  • Jul 13, 2007
If you still have the stock harmonic balancer, it's likely that it's slipped over the years, giving you a false reading.
you can check this by pulling the passenger side valve cover and bring the engine up to top dead center - you can tell when both valves on #1 cylinder are closed. You can pull the spark plug on the #1 cylinder and put long wooden dowel in the spark plug hole to help you verify when the piston at the very top of its travel.
Then, look at the timing mark on the balancer - the pointer should be pointing at 0
Good luck
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Jul 13, 2007
  • Jul 13, 2007
Try unplugging the spout connector, then set it.
U
UnderdogGN
74
  • Jul 14, 2007
thanks guys....i will check the TDC deal out to see if its off and the i always take the spout connector out when messing with timing.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Jul 14, 2007
  • Jul 14, 2007
Try unplugging the spout connector first (easy). Hopefully that's the problem.
Let us know how it turns out...good luck
9
93lxdm78
71
  • Jul 16, 2007
Do you need to remove the vavle cover to check tdc Isn't there an easier way like just removing the spark plug and using a dowel ?
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Jul 16, 2007
  • Jul 16, 2007
The dowel method by itself doesn't work becuase you don't know if the piston is on the exhaust stroke or the compression stroke.
If you don't want to pull the valve cover, you can remove the #1 spark plug and have someone bump the starter while you keep your finger over the spark plug hole. You'll feel when it's coming up to TDC because the air pressure on your finger will be alot higher than on an exhaust stroke. Just keep an eye on the timing pointer and this will get you close.
ninety15.0
1,336
  • Jul 16, 2007
Dont take the valve cover off...just take the plug out and stick your finger over the plug hole while you crank the motor over. You will hear/feel the pressure when the piston is on the compression stroke. Taking the VC off will take too much time!!!! Check for 0 on the timing pointer when # 1 is at TDC and then check that the rotor is pointing to # 1 on the cap! If not you either have a spun balancer or the dizzy is off a tooth! good luck man
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
