  • 1994 - 1995 Specific Tech
Weld-in o2 bung
  • Thread starter Thread starter 94v6GT
  • Start date Start date May 29, 2008
9
94v6GT
141
  • May 29, 2008
Where should i locate the bung for a wideband o2 sensor? Im thinking in the passenger side pipe just after the X. Is this a good/bad spot? where have you guys put yours?
im planning on having the local muffler guys put it on.
Also are all o2 bungs universal(same thread/pitch)?
Any other tips? jus checking thanks
95BlueStallion
My assy trans to myself
5,130
3,103
214
Cedar Rapids, Iowa
May 29, 2008
  • May 29, 2008
Since no one else is answering, do a search. I think I saw some posts discussing that I few weeks ago. Seems like others were saying it should be located up closer to the headers, but I could be wrong cause I wasnt reading it too closely, just browsing through.
9
94v6GT
141
  • May 29, 2008
the only reason i was thinking of putting it after the X was to read both banks, but if im not tuning individual cylinders does it matter??
Stanger007
2,015
Baton Rouge, LA
May 29, 2008
  • May 29, 2008
I like to go in the driver's side, read the manual for your particular wideband and they will give you the preferred distance from the exhaust port - usually a couple feet and around 12 o'clock.
Wes
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
May 29, 2008
  • May 29, 2008
i have mine in the long tubes right before the collector, opposit side as where the OEM sensor is
blksn955.o
3,263
st.louis mo 314
May 29, 2008
  • May 29, 2008
You need to have it fairly close to heat up the sensor. Also like said just make sure to mount it from 9-12-3 o'clock mounting it lower tends to get water to sit on/around the sensor that will shorten the life/break the sensor.
toyman
1,944
54
79
Vernon BC
May 29, 2008
  • May 29, 2008
And before any CATS. Close to the exhaust manifold is not recommended. IIRC the WB O2s are internally heated. High EGT's will kill these sensors that's why they should not be located in the NB bungs.
blksn955.o
3,263
st.louis mo 314
May 29, 2008
  • May 29, 2008
Yes, before the cats. IIRC it is like 26in. from the exh. ports of the heads.
High temps will hurt them but that temp is more an issue with Turbo cars due to the heat they put out (Innovate makes a heat sink for this as well). The avg. n/a, belt driven charger, n2o will be fine. They are internally heated but need the engine heat to keep them at that temp. I think the internal heater is to help get them to op. temps faster/smoother until they can get heated by the exh.
The goal with the distance given from the exh. port is to get them to heat up in a quick manner but not have them soo close they overheat. Generally close to the stock o2's is a good starting point and just about the distance needed.
You can got to innovate's website and watch an install video that gives the specifics of install and reasons why.
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
