Weld Prostar 15x8 wheels VS studs??!!
Xcessiv
187
Hi!
I just bought a set of 15x8 Prostars that I'm going to put on my stock rear end for drag use. Do I need to install 3" studs or if it's just necessary for 6.5" bs ones (15x10s)? If I still need to install 3" studs and I don't, is it dangerous on ET Drag slicks?
Thanks for your help, it's appreciated.
Regards.
It depends. Any NHRA sanctioned track wont let you run a slick or DR unless the stud comes out past the lug nut. This also means that you have to have open ended lugs. If you plan on going to a track you will need long studs.
