Weld wheels fit problem
  • Thread starter Thread starter haoleboy72
  • Start date Start date May 10, 2007
H
haoleboy72
60
Hillsboro, OR
May 10, 2007
  • May 10, 2007
I just picked up a set of used Weld wheels, 15 x 3.5 front, 15 x 8 rear. When I tried to install the skinnies up front, they slide all the way on and press up against the brake caliper, do i need a spacer? Do I need longer wheel studs? Not sure of any backspace numbers or if there is any. Thanks for any help.
daddystang
185
  • May 10, 2007
You shouldn't need a spacer at all, but you can't use the same lug nuts from your stock wheels (if that's what you had on there). The ones you need are rather long, because the studs don't stick out beyond the holes for the lug nuts.
Hope that helps....
M
mackey
1,284
Beverly, Massachusetts
May 10, 2007
  • May 10, 2007
How much is it off by? I believe some people grind their calipers or get a spacer.
SilverBullit
221
Tulsa, OK
May 10, 2007
  • May 10, 2007
I had to grind the bolts that hold the caliper on in order to make mine fit.............
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
