Welding problem...
  • Thread starter Thread starter 1973mach1
  • Start date Start date Jan 23, 2004
1973mach1
457
PA
Jan 23, 2004
  • Jan 23, 2004
My cousin said he knew how to weld and came over with his dad's torch and stick welder. We cut out the rusted pans with the torch and he starts welding the new ones in, after he's done the one, (we just had time to get one in) he leaves I see all these holes around the edge, one as big as a dime that goes right through to the bottom from the welder. I have more holes now then I think the rusty floor pan did. What can I do to fix these? a few of the holes are up on the hump that the tranny sits under. Is there any easy way to fix these? its not a show car so I dont care about looks. Anything I can cover them with that will harden and plug the hole? I just want it so that no water gets in.
Thanks,
Jim
D
D.Hearne
11,730
south louisiana
Jan 23, 2004
  • Jan 23, 2004
He should have at least acetylene welded them. Arc welding on sheet metal is damn near impossible without blowing holes in the metal.
1320stang
4,329
23
89
Edmond, Oklahoma
Jan 23, 2004
  • Jan 23, 2004
I agree, about the only thing now would be to acetylene weld the holes up if you don't have access to a MIG.
G
GaPonyFarm
663
Columbus, GA
Jan 23, 2004
  • Jan 23, 2004
Just get a low amperage rod and weld the holes up... Its easier with a MIG welder, but can be done with the stick welder. If all else fails get a map gas welding kit and braze them closed.
Its much easier to just tack weld the new pans in place and add new tacks to shorten the gaps until you get all the strength you need. Then use seam sealer to seal it all up. I'm assuming this is a driver, not a concourse...otherwise you'd probably have gotten it professionally done in the first place.
allcarfan
The Answer Man
2,458
North Atlanta
Jan 23, 2004
  • Jan 23, 2004
You could have the holes filled in with a mig welder....if its not a structural problem...fill them in with some JB weld.
1320stang
4,329
23
89
Edmond, Oklahoma
Jan 23, 2004
  • Jan 23, 2004
Yeah, but I bet they would have MIG'd it if they had one to begin with. Doesn't sound like they have access to one. Even a little $199 dollar flux MIG is a great investment. My $600 gas Miller 130 has saved my butt many a time and has paid for itself many times over, and I'm just a hobbyist.
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
Need help and Advise - 89 Problem Child
  • Sheela
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
evintho
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
R
Starting my 1979 notch build
  • redneck15431
  • Dec 28, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2025
redneck15431
R
Progress Thread Cobra II Resurrection
  • welder4956
  • Mar 16, 2025
1974 - 1978 Mustang II Talk & Tech Apr 25, 2026
welder4956
