Wet N20 System Questions
No I'm not going to ask the usual "how big a shot?" or refer to it as "NAASSSS."
My questions are regarding the fuel system.
1. If the wet system supplies the additional fuel for the N20's added oxygen, do I still need to have injectors to handle the engines power while on the bottle? To simplify, if I have a 300 hp engine and add an additional 100 hp with a wet system, do I need injectors to handle 300 or 400 horse? The 300hp set right? I'm going to be running a separate tank/pump/filter for the system, idk if that makes a difference.
2. Do I have to worry about a box upper intake (that I'm making) pudding fuel? Does that usually happen with a certain power level? Should I fab up some "burst" plugs like I see some n20 set-ups using? Any other things to consider in the design?
Thanks to everyone who throws in their 2 cents. I only had a dry system in the past.
