Wet or Dry Nitrous?
$uperstang
476
Detroit, MI
Just need some suggestions. If I was going to stay with my current set-up. Would it be better to go with a Dry Kit as opposed to Wet? What is the major difference between the two? What do some of you recommend, I was planning on a like a 75-100HP shot just for some added ET improvements?
Yeah, I've been wondering about this one myself. The dry kit sounds easier to install, because it gets extra fuel from jacking up the fuel pressure to the injectors. The wet kit sounds safer because it doesn't involve high fuel pressures and potential variances in fuel delivery from different pumps. But then again, the wet kit looks like its bar would be an intake restriction when running on the motor. Anybody have any experience with these?
I used to be a super wet kit advocate but not anymore. A well planned dry kit is the way to go. You jst need to make sure you have enough injector and fp for your unit and your set. My wet kits had problems with, puddling, backfiring, and running crappy with a low bottle. I had one of those nos 5115 kits (I think that's the #) and it worked flawlessly.
I would suggest a performer rpm intake and the edelbrock performer rpm nitrous kit. It uses a spary bar plate between the upper and lower manifolds making it so each cylinder is tunable. I think it's the best design there is. Plus you need to upgrade from that cobra intake with that stroker and those heads.
No matter what you do make sure you get it TUNED!
I'm not sure what you mean by sneeky peat. Edelbrock also makes a concealed nitrous system. Which is pretty much just a 12oz bottle that can be hidden anywhere, and no one will ever have to know you're "cheating." Especially with the spray bar plate. :banana:
dry, unless the nozzle is mounted in the lower manifold like a direct port or the edelbrock kit mentioned. i say this as a wet kit sprayed into the upper has to negotiate several bends and has the tendency to puddle and make big boom.
If your making big shot HP you will be running grossly over rich under daily driving conditions.
fiveohGT said:
Thats an interesting kit. The kit says that it is for use on carburetors only. What would be needed to make sure you had a enough fuel when you randomly decided to hit the botton on the go? Some kind of chip with a switch on it that can switch fuel pressure/tunes? In other words, how can you safely run this kit?
Yes it is. I almost put one on a 5hp B&S. :) Beleve me you can fab it up to work with FI. I had a holley quadrajunk plate on a friggin Celebtity...... They go for around $50 on Ebay used.
Most cars run far to rich at WOT. I would not worrie about running extra fuel. Especially with that kit. If you want more info PM me.
bimmertech said:
afm sells a 250-up dry kit with a pms. it can and is being done, albiet at a much greater price than a homemade direct port.
A 250 dry kit eh? For some reason I don't like the sound of it. I'm sure you'd have to upgrade the fuel pump.......
i run a nitrousworks wet kit with a 150 shot with no prob. no backfiring or puddling, run it at the track at least 4 times every week, timing set at 8, two step coolder plugs(autolite ar94s), hobbs fuel pressure safety switch, paid $350 on ebay, wet or dry you wont go wrong good luck to you!
I've heard nothing but satisfaction with the Zex dry kit. Only downside is that it only goes from 75-125, but I hear of many going up to 150 using nitrous express jet sizes (although going up to 150 is not recommended by Zex). Anybody know which NX jets will take the Zex kit up to 150? I've been thinking of purchasing this one myself if it'll work up to 150.
I had the NOS 5115-2 (stage 2 ) Dry kit and used a 175 shot and my car ran 11.70's. I sold that kit and bought a Cold Fusion Nitrous wet kit with 15lb bottle and is adjustable up to 200 shot. It feels the same as the dry kit to me, no difference. I tried the 200 shot but my car would not hook even with slicks, I would spin 1st gear off the line a little bit(don't know why), guess I need suspension work now!!!. I would just go with a dry kit, it's just as good as a wet kit IMO!! I ran the same times with both kits!!!!
