Suspension What about these Subframes
Just read through this thread. All the cliche advice applies:
Buy once cry once
You get what you pay for
Too good to be true
Just get the good ones and be done with it!! You won’t be disappointed.
Reactions: gkomo
They work well and it seems safer to me than jack stands. Still wish I had a tall ceiling and a lift....
nice and I actually built some like yours out of 2x8's or 10's.
My son's Race ramps are actually the long drive up on ones.
I have some 2 X 6 ones also.. they are not as tall as these and when I have to jack up one side at a time on a car I use them in between the final jack up to the height of the Race Ramps....
Reactions: from6to8
If you want to spend the same time, effort, and money to weld them in then go for it. I would rather spend the $40 or so more dollars and know I have the better units.
Is it necessary to have the subframes fastened at the seat brackets underneath? I noticed today when swapping my rear lower arms that one side wasn't fastened, I'll check the other side tomorrow. Not sure rather the nuts were missing when the muffler guy welded them up or what.
If they are seat bolts, then yeah, bolt them down. Can you move that end of the seat up and down?
I actually don't think the seat is moving as if those are the seat bolts that lock the seats down but it seems they should be. I will check when I go outside later & I'll fasten anyway just to be safe
Whoever installed mine decided to go the extra mile under the seat area.
Yeah it looks like that should suffice since it's welded up in that area even though I don't see the seat brackets themselves. As for mine upon further inspection the seat bolts just fasten through the floor pan with no nuts on them and the brackets for the subframes just kind of sits over those so everything's welded up nice. As some have said it's no reason to put nuts on them as the seats don't have them anyway. I guess it won't hurt too but yesterday I was tackling swapping out rear lower control arms and all of that so I'm not worried about it
I made this post a while back in a another thread
"So i turned the rear bolts into studs.
The factory bolts will work, but it's really close with the thickness of the carpet, when you put them in from the top, you can crank them down and crush the carpet and padding get the threads you need on the bottom side, not so easy when they face up.
So i bought them like half an inch longer.
They are m10 1.5 with a 40mm length. 10.9 grade, which i'm not sure how compares to Grade 8 which is what i would normally buy.
Oddly enough advance auto stocks them, their website makes it seem like $4.79 per bolt, but when i got there, it's actually a 3 pack for that amount of money.
I also ordered some for nuts for the top.
Same size obviously, but i got ones to match the front bolts, which are apparently called "Free spin washer nuts", hopefully they will go on easier as they start to get tight."
Imo, this is the way the back should be done.
i'm just going to throw whatever nuts fit the stock seat bolts lol......
Nothing wrong with that, but every time you take a seat bolt out, they are going to fall off. I was tired of it happening. I'm 6'1, so any work in the front interior is easier by removing the seat. The added bonus too is that you never have to deal with getting past the carpet with the bolt anymore either.
i just re read your post as to what you did and understood it better the second time lol. I feel you on that but as for me I don't remove my seats really ever to be honest for anything I do to the car and even for the interior, working on stereos and such, ect.
Maximum Motorsports - Made of 1.5" x 2" x 0.083" wall thickness rectangular tubing
SVE (LMR) - 1"x 2" Steel Construction, noodled around and found the wall thickness is 0.0625"
Steeda - 1.5" x 2.0" x 0.083"
Kenny Brown - 1.5" x 2.0" x 0.083" mild steel
UPR - 1.25" x 2.0" x 0.083"
Another option is Global West (I have them on both cars) which are made from 1.625" x 0.125" wall DOM tubing. Round tube resists torsional forces better than square or rectangular tube and they install to the side of the factory subframes which increases ground clearance. They offer seat braces (I have them) as well as rocker rails (should be used with a vert) and also offer competition series which is like the Kenny Brown extreme matrix setup.
Anyhow, I would pass on the SVE's as the thinner the wall thickness the less torsional force they can resist compared to a thicker wall unit. Any of the other ones are going to do you a good job.
I wanted to add a follow up to this post as I came across it looking for the same info on the Ebay subframe connectors as the original poster.
I ordered a pair and they arrived with the following specs:
Ebay no-name - 1.0" x 2.0" x 0.083" wall thickness rectangular tubing mild steel with no end caps or welded gussets on the crimped/bent sections. I called out the dimensions, end caps and gussets as the Steeda ones they claim to match are 1.5" x 2.0" and have the welded gusset plates reinforcing the crimped/bent sections. Overall they aren't bad as I got them for $87 shipped (used a coupon discount) and can fab and weld the missing gusset and end plates on myself.
Ebay no-name - 1" x 2.0" x 0.083" wall thickness rectangular tubing mild steel with no end caps or welded gussets on the crimped/bent sections. I call out the end caps and gussets as the Steeda ones they claim to match have the welded gusset plates reinforcing the crimped/bent sections. Overall they aren't bad as I got them for $87 shipped (used a coupon discount) and can fab and weld the missing gusset and end plates on myself.
i gotta look back and see which ones I bought. I think I got the ones off ebay .
Nope, it was the SVE from LMR. I haven't started on the car yet though as the engine is just getting underway finally soon after the rods come in to the builder. Started the process early 2025 lol but have been messing with my 94 all of this year well from Jan to about April after adding the Vortech to it.
I've since decided with the 95 331 build to put a V3 on it from the start. I was going to add one later on down the road but it made more sense to do it right away. I'll be black friday shopping for deals lol. As for the subframes I'll likely be getting before the year is out. I don't expect to have the engine until likely early '27.
Seat brackets start at about 1:00 and you can see they install nuts on the bolts to pull the seat brackets up to the floor pan. Ties everything together and makes the seats move less.
View: https://youtu.be/TgSju5PQ2pE?si=Rg08gYd8HkxEcZDM
without going back and re reading my own thread let me try and refresh. So the brackets just get fastened via nuts and there's no requirement of the brackets themselves to be welded? LMR did send me the brackets for the 94 and I have the subframes set to go on the 95 at some point befor the EOY.
If the brackets just bolt up then I'll add them myself and I'm sure they'll have to be secured with nuts. When I get the 95 done I'll have him throw those on while he's under there.
No i believe the brackets get welded to the subframes, the bolts are just for the seats to be mounted to.
